CMK version: 2.2.0p7.cre
OS version: Centos 8.5 (migrating to Rocky)
Error message: The Azure Agent Info shows the following error randomly on some of your hosts.
Usage client: Too many requests. Please retry.CRIT , Remaining API reads: 11916, Monitored groups: ***********, **********, Warnings: 0, Exceptions: 0
The actual Azure services like CPU, RAM etc are working fine despite that error.
As you can see there are plenty of API reads remaining.
It appeared at the end of last week, while I was still i version 2.1, and I upgraded to version 2.2 to see if it would help. It did not.
Anyone have the same issue? Is there a way to fix it?
Output of ācmk --debug -vvn hostnameā: (If it is a problem with checks or plugins)
Checkmk version 2.2.0p7
+ FETCHING DATA
Source: SourceInfo(hostname='*******', ipaddress=None, ident='special_azure', fetcher_type=<FetcherType.SPECIAL_AGENT: 6>, source_type=<SourceType.HOST: 1>)
[cpu_tracking] Start [7f300485f8d0]
Read from cache: AgentFileCache(*******, path_template=/omd/sites/onpremises/tmp/check_mk/data_source_cache/special_azure/{hostname}, max_age=MaxAge(checking=0, discovery=120, inventory=120), simulation=False, use_only_cache=False, file_cache_mode=6)
Not using cache (does not exist)
Calling: /omd/sites/onpremises/share/check_mk/agents/special/agent_azure --tenant ******* --client ******* --secret '*******' --subscription ******* --services users_count ad_connect app_registrations usage_details Microsoft.Compute/virtualMachines Microsoft.Network/virtualNetworkGateways Microsoft.Sql/servers/databases Microsoft.Storage/storageAccounts Microsoft.Web/sites Microsoft.DBforMySQL/servers Microsoft.DBforPostgreSQL/servers Microsoft.Network/trafficmanagerprofiles Microsoft.Network/loadBalancers --explicit-config group=******* group=******* --require-tag-value Environment PROD
Write data to cache file /omd/sites/onpremises/tmp/check_mk/data_source_cache/special_azure/*******
Trying to acquire lock on /omd/sites/onpremises/tmp/check_mk/data_source_cache/special_azure/*******
Got lock on /omd/sites/onpremises/tmp/check_mk/data_source_cache/special_azure/*******
Releasing lock on /omd/sites/onpremises/tmp/check_mk/data_source_cache/special_azure/*******
Released lock on /omd/sites/onpremises/tmp/check_mk/data_source_cache/special_azure/*******
[cpu_tracking] Stop [7f300485f8d0 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.65, children_system=0.19, elapsed=11.269999999552965))]
Source: SourceInfo(hostname='*******', ipaddress=None, ident='piggyback', fetcher_type=<FetcherType.PIGGYBACK: 4>, source_type=<SourceType.HOST: 1>)
[cpu_tracking] Start [7f3004927c10]
Read from cache: NoCache(*******, path_template=/dev/null, max_age=MaxAge(checking=0.0, discovery=0.0, inventory=0.0), simulation=False, use_only_cache=False, file_cache_mode=1)
No piggyback files for '*******'. Skip processing.
[cpu_tracking] Stop [7f3004927c10 - Snapshot(process=posix.times_result(user=0.010000000000000009, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))]
+ PARSE FETCHER RESULTS
<<<azure_ad:sep(124)>>> / Transition NOOPParser -> HostSectionParser
Transition HostSectionParser -> NOOPParser
<<<azure_app_registration:sep(124)>>> / Transition NOOPParser -> HostSectionParser
PiggybackMarker(hostname='*******') / Transition NOOPParser -> PiggybackParser
PiggybackMarker(hostname='*******') SectionMarker(name=SectionName('labels'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='\x00') / Transition PiggybackParser -> PiggybackSectionParser
Transition PiggybackSectionParser -> NOOPParser
<<<azure_agent_info:sep(124)>>> / Transition NOOPParser -> HostSectionParser
PiggybackMarker(hostname='*******') SectionMarker(name=SectionName('azure_usagedetails'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='|') / Transition PiggybackParser -> PiggybackSectionParser
PiggybackMarker(hostname='*******') / Transition PiggybackSectionParser -> PiggybackParser
<<<azure_usagedetails:sep(124)>>> / Transition NOOPParser -> HostSectionParser
PiggybackMarker(hostname='*******') SectionMarker(name=SectionName('azure_virtualmachines'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='|') / Transition PiggybackParser -> PiggybackSectionParser
<<<azure_virtualmachines:sep(124)>>> / Transition NOOPParser -> HostSectionParser
<<<azure_sites:sep(124)>>> / Transition NOOPParser -> HostSectionParser
<<<azure_trafficmanagerprofiles:sep(124)>>> / Transition NOOPParser -> HostSectionParser
<<<azure_storageaccounts:sep(124)>>> / Transition NOOPParser -> HostSectionParser
<<<azure_resource_health:sep(124)>>> / Transition NOOPParser -> HostSectionParser
No persisted sections
HostKey(hostname='*******', source_type=<SourceType.HOST: 1>) -> Add sections: ['azure_ad', 'azure_agent_info', 'azure_app_registration', 'azure_resource_health', 'azure_sites', 'azure_storageaccounts', 'azure_trafficmanagerprofiles', 'azure_usagedetails', 'azure_virtualmachines']
HostKey(hostname='*******', source_type=<SourceType.HOST: 1>) -> Add sections: []
Storing piggyback data for: '*******'
Trying to acquire lock on /omd/sites/onpremises/tmp/check_mk/piggyback/*******/*******
Got lock on /omd/sites/onpremises/tmp/check_mk/piggyback/*******/*******
Releasing lock on /omd/sites/onpremises/tmp/check_mk/piggyback/*******/*******
Released lock on /omd/sites/onpremises/tmp/check_mk/piggyback/*******/*******
Received piggyback data for 2 hosts
[cpu_tracking] Start [7f3003cbf1d0]
value store: synchronizing
Trying to acquire lock on /omd/sites/onpremises/tmp/check_mk/counters/*******
Got lock on /omd/sites/onpremises/tmp/check_mk/counters/*******
Releasing lock on /omd/sites/onpremises/tmp/check_mk/counters/*******
Released lock on /omd/sites/onpremises/tmp/check_mk/counters/*******
Piggyback file '/omd/sites/onpremises/tmp/check_mk/piggyback/*******/*******': Successfully processed from source '*******'
[cpu_tracking] Stop [7f3003cbf1d0 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))]
[special_azure] Success, [piggyback] Successfully processed from source '*******', execution time 11.3 sec | execution_time=11.270 user_time=0.010 system_time=0.000 children_user_time=0.650 children_system_time=0.190 cmk_time_ds=10.430 cmk_time_agent=0.000
