Bakery example without deprecated files
is there any example of an extension using the agent bakery available that is fully state of the art and does not use any files that get reported as “deprecated”?
I’m looking for an example that contains a bakery plugin, an agent plugin and a ruleset for the bakery. I’ve been looking through the Checkmk exchange, but all the packages I can find contain files that are flagged as deprecated.
Regards,
Sven
No, this is not possible with CMK 2.3.
You can have a look at a daily 2.4 build. There you should find something like you want. I had no time to look by myself :smiley: until now.
Ah, that explains it. Good to know, thanks. :slight_smile:
