Barracuda / Phion plugin additions
Hi all.
As we use a bunch of Barracuda Cloudgen firewalls globally, I used the plugin from GitHub - jiuka/checkmk_phion: Phion MIB based check · GitHub to check our firewalls.
After a while I liked to expand it, so I added a hardware check. Today I also added a VPN tunnel check (TINA & IPSEC, checks count of live transports).
Testers wanted as “It works for me” :smiley:
My code is under GitHub - tonivanremortel/checkmk_phion: Phion MIB based check · GitHub
(Had a pull request open for a while on the original repo, but it seems that the original owner is not following up on his git account).
Thanks!
Hi @toni.van.remortel !
If you want, please also consider adding it to the Checkmk Exchange, so others could easily find it :slight_smile:
Hi @Sara ,
I have just uploaded it for review!
