Best-Practice for monitoring internal network
CMK version:
2.3.0p6
OS version:
Rocky Linux 9
Best-Practice
What is the best-practice for the following use-case:
I would like to monitor hosts which are in a private network and therefore not accessible via a pubic IP. However the hosts are accessible with a bastion-host (ssh ProxyJump).
What I’ve done so far is the following:
  • Added the checkmk-agent on all hosts
  • On the bastion-host i wrote a script which is collecting the data of every internal host (piggy-back).
  • The bastion -host is added to Checkmk-Server normally (with the public-ip)
  • The other hosts are added to Checkmk with the No-IP-flag and “No API Integration and No-Check-MK-Agent” and Always use and expect piggyback data Remark: If a add an Check-MK-Agent then I got an error that “no datasource” is found.
This is working quite well. However I cannot make use of the Agent Backery. Probably because of the “No Check-MK-Agent”-configuration.
Since my Use-Case is probably quite common, I would like to know what is the 'Best-pracice" for it, unfortunatelly I did not found anything in the official documentation.
And: I would like a solution without installation of an checkmk-server on the internal network. (CheckMK MSP)
not sure what you mean but placing your hosts directly on the public internet is really bad. dont do that
thats not very common use-case, the most common solution for your problem is to use the cloud edition where you can push data even if they are on private networks as long as they have internet access via NAT
We have really isolated networks that we are not allowed to talk to, all internal for that you can use check via SSH and just use a jumphost
