Best way to monitor S2D - HyperV Cluster
Hi to all,
can anyone recommend me a way to monitor S2D / a hyperV Cluster?
I have seen some github scripts is this the best way?
This are the scripts that I have found:
Can anyone tell me where I have to insert this script?
I’m not a pro user using checkmk maybe someone can guide me through this process.
Thank you very much!
for 2.1 there is Andreas check, I will migrate it to the 2.2 “API” in the next days…
I installed the mkp file on the omd I see that the mkp hyperv_cluster 2.0 is enabled.
But how can I now monitor the hyper-v cluster?
Can you give me a hint?
Normaly I find the checks under other integrations but this time I cannot find anything:
The cluster data is fetched by Powershell scripts triggered by the checkmk Agent on the Cluster nodes, you can either bake them into a MSI package in the bakery or put them manually in the agents Plugin folder with the Raw Edition.
Ok thank you, I was able to copy the files now manually (hyperv checks) into this path: /local/lib/check_mk/base/plugins/agent_based and they are now into this folder.
Can you provide me the next steps?
Or should I be able now to rescan the object and see the available checks?
I can’t find something helpful from the documentation.
Thank you @aeckstein
Hi Matthias,
a discovery of the hosts should be enough.
You can try to run the powershell scripts manually and see if they provide a valid output and you can see if the checkmk agent output contains the hyper_v sections e. g. <<<hyperv_cluster_general>>> .
Hey @aeckstein,
sorry for my late answer on that, was in trouble with other stuff until yet.
I tried to run the powershell script manually (with and without admin credentials) and there I got this error:
So manually the powershell script doesn’t work.
For this reason the checks on checkmk site don’t work too.
I’m still stuck here…can you tell me where (checkmk server, server etc.) I should try to run the powershell script manually?
I think you need to test it inside a elevated powershell.
CheckMK agent runs normally as local system and has these rights.
Where should the checkmk agent run? It can’t run on the node, unfortunately I haven’t really understood that yet, maybe you can help me.
Thank you.
The PowerShell scripts must run on the HyperV node.
That means a CheckMK agent must be installed on the HyperV nodes.
Ok thank you, but is there any official guideline how to set this up?
It is the same as with any other agent plugin script.
