I will send you a PM on this.
This is an option, i don’t think a good one, but still…
First modify the original register.snmp_section and register.check_plugin part like this
_bgp_oids = SNMPTree(
base='.1.3.6.1.2.1.15.3.1', # BGP4-MIB::BgpPeerEntry
oids=[
'7', # bgpPeerRemoteAddr
'2', # bgpPeerState
'3', # bgpPeerAdminStatus
'9', # bgpPeerRemoteAs
'10', # bgpPeerInUpdates
'11', # bgpPeerOutUpdates
'12', # bgpPeerInTotalMessages
'13', # bgpPeerOutTotalMessages
'15', # bgpPeerFsmEstablishedTransitions
'16', # bgpPeerFsmEstablishedTime
'24', # bgpPeerInUpdateElapsedTime
register.snmp_section(
name='bgp_peer',
parse_function=parse_bgp_peer,
fetch=_bgp_oids,
detect=exists('.1.3.6.1.2.1.15.3.1.1.*')
_bgp_discovery_default_parameters = {
'build_item': [
# 'remote_address',
'remote_as',
# 'address_family',
# 'routing_instance',
_bgp_check_default_parameters={
'minuptime': (7200, 3600),
'peer_list': [],
'peernotfound': 2,
'admindown': 1,
'noprefixlimit': 1,
'accepted_prefixes_upper_levels': (None, None),
'accepted_prefixes_lower_levels': (None, None),
'neighborstate': {
'1': 2, # idle
'2': 1, # connect
'3': 1, # active
'4': 1, # opensent
'5': 1, # openconfirm
'6': 0, # established
'internal_item': None,
register.check_plugin(
name='bgp_peer',
service_name='BGP peer %s',
discovery_function=discovery_bgp_peer,
discovery_default_parameters=_bgp_discovery_default_parameters,
discovery_ruleset_name='discovery_bgp_peer',
check_function=check_bgp_peer,
check_default_parameters=_bgp_check_default_parameters,
check_ruleset_name='bgp_peer',
Create a copy of register.snmp_section and register.check_plugin for each VRF with a new name, if you have duplicate peers in the VRFs you need to change the service name
name='bgp_peer_vrf_1',
parsed_section_name='bgp_peer',
fetch=_bgp_oids,
service_name='BGP peer VRF1 %s',
Than add a context rule for each new section → rediscover your device…
BGP peer 30.30.30.30 Peer state: idle
BGP peer 99.99.99.99 Peer state: idle
BGP peer VRF1 30.30.30.30 Peer state: idle
BGP peer VRF1 99.99.99.99 Peer state: idle
This depends on your system, if your default VRF has a label/context assigned than you can do this.
@Checkmk_tribe I my opinon this a design flaw in CMK that you don’t have a option to also fetch the default context for a snmp_section as soon as you are starting to use contexts. Also that the plugins have no knowledge that the data came from a context is suboptimal…
If you configure a context rule for each bgp snmp section (except for the original one) i think you sould get all the peers from the VRFs and from the global table.
