I’ve installed the bgp_peer plugin in checkmk2.0.0p1 but got the following errors:
cmk --debug --checks bgp_peer router.REDACTED.lan
File “/omd/sites/REDACTED/lib/python3/cmk/base/config.py”, line 1986, in _extract_agent_and_snmp_sections
create_snmp_section_plugin_from_legacy(
File “/omd/sites/REDACTED/lib/python3/cmk/base/api/agent_based/register/section_plugins_legacy/init.py”, line 235, in create_snmp_section_plugin_from_legacy
detect_spec = create_detect_spec(
File “/omd/sites/REDACTED/lib/python3/cmk/base/api/agent_based/register/section_plugins_legacy/convert_scan_functions.py”, line 397, in create_detect_spec
_compute_detect_spec(
File “/omd/sites/REDACTED/lib/python3/cmk/base/api/agent_based/register/section_plugins_legacy/convert_scan_functions.py”, line 373, in _compute_detect_spec
return _ast_convert_dispatcher(expression_ast)
File “/omd/sites/REDACTED/lib/python3/cmk/base/api/agent_based/register/section_plugins_legacy/convert_scan_functions.py”, line 323, in _ast_convert_dispatcher
return _ast_convert_compare(arg)
File “/omd/sites/REDACTED/lib/python3/cmk/base/api/agent_based/register/section_plugins_legacy/convert_scan_functions.py”, line 220, in _ast_convert_compare
assert isinstance(comp_ast.left, ast.Call)
AssertionError
The above exception was the direct cause of the following exception:
File “/omd/sites/REDACTED/bin/cmk”, line 79, in
errors = config.load_all_agent_based_plugins(check_api.get_check_api_context)
File “/omd/sites/REDACTED/lib/python3/cmk/base/config.py”, line 1415, in load_all_agent_based_plugins
errors.extend(load_checks(get_check_api_context, filelist))
File “/omd/sites/REDACTED/lib/python3/cmk/base/config.py”, line 1563, in load_checks
errors = (_extract_agent_and_snmp_sections(validate_creation_kwargs=did_compile) +
File “/omd/sites/REDACTED/lib/python3/cmk/base/config.py”, line 2005, in _extract_agent_and_snmp_sections
raise MKGeneralException(exc) from exc
cmk.utils.exceptions.MKGeneralException
This looks like the same error here: Check_mk-interfaces no perfdata
The output of cmk -R:
Failed to auto-migrate legacy plugin to section: bgp_peer
Please refer to Werk 10601 for more information.
Generating configuration for core (type nagios)…Precompiling host checks…OK
Validating Nagios configuration…OK
OK
Restarting monitoring core…OK
I’ve looked into Werk 10601, but could not find a solution.
I would love to get this plugin working, but I don’t know where to start.
