The CRE 1.6.0p14, the file storeonce_clusterinfo is:
def inventory_storeonce_clusterinfo_space(parsed):
return [(‘Total Capacity’, {})]check_info[‘storeonce_clusterinfo.space’] = {
‘inventory_function’: inventory_storeonce_clusterinfo_space,
‘check_function’: check_storeonce_space,
‘service_description’: “%s”,
‘has_perfdata’: True,
‘includes’: [“size_trend.include”, “df.include”, “storeonce.include”],
‘group’: “filesystem”,
‘default_levels_variable’: “filesystem_Default_levels”,
and should be
return [(‘Total Capacity’, {})]def check_storeonce_clusterinfo_space(item, params, parsed):
total_mb = float(parsed[‘Total Capacity (bytes)’])/1024/1024
free_mb = float(parsed[‘Free Space (bytes)’])/1024/1024yield df_check_filesystem_list(item, params, [ (item, total_mb, free_mb, 0) ]) dedup = float(parsed['Dedupe Ratio']) yield 0, "Dedup: %.2f" % dedup
‘check_function’: check_storeonce_clusterinfo_space,
