BUG: oracle_asm_diskgroups check --> Unbound variable error for 'dg_sizefactor'
CMK version: 2.2.0p23.cme
OS version: Red Hat Enterprise Linux Server release 7.9
Exception: UnboundLocalError (cannot access local variable ‘dg_sizefactor’ where it is not associated with a value)
Traceback:
  File "/omd/sites/VCloud/lib/python3/cmk/base/agent_based/checking/_checking.py", line 413, in get_aggregated_result
    consume_check_results(
  File "/omd/sites/VCloud/lib/python3/cmk/base/api/agent_based/checking_classes.py", line 484, in consume_check_results
    for subr in subresults:
  File "/omd/sites/VCloud/lib/python3/cmk/base/api/agent_based/register/check_plugins.py", line 93, in filtered_generator
    for element in generator(*args, **kwargs):
  File "/omd/sites/VCloud/lib/python3/cmk/base/plugins/agent_based/oracle_asm_diskgroup.py", line 501, in cluster_check_oracle_asm_diskgroup
    yield from check_oracle_asm_diskgroup(item, params, node_section)
  File "/omd/sites/VCloud/lib/python3/cmk/base/plugins/agent_based/oracle_asm_diskgroup.py", line 408, in check_oracle_asm_diskgroup
    total_mb = total_mb // dg_sizefactor
Trying to acquire lock on /omd/sites/VCloud/tmp/check_mk/counters/moncxdbp_RAC
Got lock on /omd/sites/VCloud/tmp/check_mk/counters/moncxdbp_RAC
Releasing lock on /omd/sites/VCloud/tmp/check_mk/counters/moncxdbp_RAC
Released lock on /omd/sites/VCloud/tmp/check_mk/counters/moncxdbp_RAC
[cpu_tracking] Stop [7f76df053150 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))]
Trying to acquire lock on /omd/sites/VCloud/var/check_mk/crashes/base/1d62f0ea-e448-11ee-88f3-2b5f9c05c3e4/crash.info
Got lock on /omd/sites/VCloud/var/check_mk/crashes/base/1d62f0ea-e448-11ee-88f3-2b5f9c05c3e4/crash.info
Releasing lock on /omd/sites/VCloud/var/check_mk/crashes/base/1d62f0ea-e448-11ee-88f3-2b5f9c05c3e4/crash.info
Released lock on /omd/sites/VCloud/var/check_mk/crashes/base/1d62f0ea-e448-11ee-88f3-2b5f9c05c3e4/crash.info
  File "/omd/sites/VCloud/bin/cmk", line 118, in <module>
    exit_status = modes.call("--check", None, opts, args)
  File "/omd/sites/VCloud/lib/python3/cmk/base/modes/__init__.py", line 68, in call
    return handler(*handler_args)
  File "/omd/sites/VCloud/lib/python3/cmk/base/modes/check_mk.py", line 2003, in mode_check
    with error_handler:
  File "/omd/sites/VCloud/lib/python3/cmk/checkers/error_handling.py", line 59, in __exit__
    self._result = _handle_failure(
  File "/omd/sites/VCloud/lib/python3/cmk/checkers/error_handling.py", line 95, in _handle_failure
    raise exc
  File "/omd/sites/VCloud/lib/python3/cmk/base/modes/check_mk.py", line 2006, in mode_check
    check_result = checking.execute_checkmk_checks(
  File "/omd/sites/VCloud/lib/python3/cmk/base/agent_based/checking/_checking.py", line 117, in execute_checkmk_checks
    service_results = check_host_services(
  File "/omd/sites/VCloud/lib/python3/cmk/base/agent_based/checking/_checking.py", line 293, in check_host_services
    submittables = [
  File "/omd/sites/VCloud/lib/python3/cmk/base/agent_based/checking/_checking.py", line 303, in <listcomp>
    else get_aggregated_result(
UnboundLocalError: cannot access local variable 'dg_sizefactor' where it is not associated with a value
OMD[VCloud]:~$
Agent Output:
<<<oracle_asm_diskgroup:sep(124)>>>
MOUNTED|NORMAL|PRODARCHEXT|4096|4194304|204792|307188|290708|FG1|N|REGULAR|0|8640000|3
MOUNTED|NORMAL|PRODARCHEXT|4096|4194304|204792|307188|290708|FG2|N|REGULAR|0|8640000|3
MOUNTED|NORMAL|PRODDATAEXT|4096|4194304|204792|921564|311852|FG1|N|REGULAR|0|8640000|9
MOUNTED|NORMAL|PRODDATAEXT|4096|4194304|204792|921564|311852|FG2|N|REGULAR|0|8640000|9
MOUNTED|NORMAL|PRODTOPEXT|4096|4194304|0|51196|820|FG1|N|REGULAR|0|8640000|1
MOUNTED|NORMAL|PRODTOPEXT|4096|4194304|0|51196|820|FG2|N|REGULAR|0|8640000|1
MOUNTED|EXTEND|VOTINGEXT|4096|4194304|0|10236|9852|FG1|Y|REGULAR|0|8640000|1
MOUNTED|EXTEND|VOTINGEXT|4096|4194304|0|10236|9856|FG2|Y|REGULAR|0|8640000|1
MOUNTED|EXTEND|VOTINGEXT|4096|4194304|0|10236|9864|FG3|Y|REGULAR|0|8640000|1
MOUNTED|EXTEND|VOTINGEXT|4096|4194304|0|10236|9860|FG4|Y|REGULAR|0|8640000|1
MOUNTED|EXTEND|VOTINGEXT|4096|4194304|0|10236|9860|FG5|Y|REGULAR|0|8640000|1
MOUNTED|EXTEND|VOTINGEXT|4096|4194304|0|10236|9852|FG6|Y|REGULAR|0|8640000|1
MOUNTED|EXTEND|VOTINGEXT|4096|4194304|0|10240|10196|FG7|Y|QUORUM|0|8640000|1
I have tried the steps mentioned in,
but didn’t solve my issue.
Can someone please help me to resolve this issue?
Thank you,
Benson Thomas
Relative easy solution. Copy the “oracle_asm_diskgroup.py” to your “~/local/lib/check_mk/base/plugins/agent_based/” inside your site.
At line 295 where you see some variables filled with values you insert the line.
    dg_sizefactor = 1
Pay attention to the correct indentation and don’t use tabs.
The problem is that dg_sizefactor can be unbound with the local code. The is a “coding style” problem → if - elif without anything if nothing matches.
PS: changed the title to make the problem a little bit clearer
@andreas-doehler
Thank you for the support.
The provided suggestion worked for me.
Regards,
Benson Thomas
Systems Support
