The problem looks like it is defaulting to “all services” if you use such a regex inside the quicksearch.
With 2.0 you have exactly the same problem / behaviour.
h: ne.*xt → leads to
If you use the “ne.*xt” inside the host search view you get the correct result.
Exactly the same happens for a service search inside the quicksearch field.
Check the character before * if it’s another common regular expression character and in this case not substitute it. The outcome of abc.*xyz is different to abc..*xyz from an regular expression point. This, I think, is not intuitive at all.
which I think is a good feature to get all needed systems on one screen.
I understand it may be confusing to people who just want to use globbing but I think regular expressions are a pretty important feature. Making it work like 95% would be very confusing as Martin wrote.
Sorry, i did not follow this thread because we discussed this internally and came to the conclusion as stated.
So we will not change that behaviour in the near future
