Hi all,
I believe I have found a bug in the checkMK software. We are currently using the Enterprise Edition here on version 2.2.0p22.cee. I believe we have identified a bug that has to do with the report generation tool. When editing report content, there is an option to add a heading for the view under the parameters section. You can add a heading and save, and this will add a title to the report generated as selected, however if you go back in to edit this element it will uncheck “A heading for the view” and reset the title. If you proceed to make any other changes and save this element the title will no longer appear on reports and be removed from the element. All other settings on this page do not do this from what I have seen.
