Hey,
it seems that the filter options don’t work if I view a BI-Aggregation:
I tried several constellations with the filter options, I always get “all or nothing” but not "everything except “OK” ".
2.2.0p8 EE
Josef
Hey,
2.2.0p8 EE
Josef
I think you are looking for this:
This setting changes the view for all aggregations permanently. But sometimes I just want to set a filter not a global setting.
If there is a filter option it should filter I guess. I’did’t build the filter by myself, it’s a default cmk filter option to “filter by state” - so if I select “Crit” only there should be only critical states.
Josef
