I’m trying to bulk import a bunch of hosts with an internal host name. They are web exposed with a public dns name. I want a clean dashboard so i’ll be using the internal host name with a manual ipv4 address to the public dns name. You can do this manually without any problem. When bulk importing a hostname + public dns/fqdn in the IPv4 address field I get an error:
Please enter a valid hostname or IPv4 address. Only letters, digits, dash, underscore and dot are allowed.
tl;dr
Manually create host with hostname and fqdn in ipv4 address field = ok
Bulk import host with hostname and fqdn in ipv4 address field = error
I made a short check with actual 2.2 and has no problem to do a bulk import with fqdn inside the ipv4 field. You are sure that your data has no other special characters inside, beside the visible ones.
