i was trying to use BI for my Infrastructure
First try is to check various Websites and various SSL-Certificates.
Unfortunately, check_mk uses the same check (check_http) for both “checks”.
Now my idea is to create a BI-Tree to get following:
Leaf 1
“HTTP-GET” checks to test Availability only on some Websites
Leaf 2
Certificate-Checks to test Expiration
At a created view i can get only Certificatechecks with a Searchfilter on field “STATUS DETAIL”, works like a charm.
How can i use a Searchfilter for “STATUS DETAIL” in BI?
GREETZ
JP
