I want to execute plug-ins via MRPE. I followed the steps The agent for Windows in detail under section “6.2. Executing plug-ins via MRPE”. I’ve done the configuration but doesn’t work.
If your PowerShell script outputs 1 - OK DNS is reachable it is not a Nagios Plugin and cannot be started via MRPE. A Nagios Plugin exits with the status code, where 0 is OK, 1 is WARN and 2 is CRIT.
