I have several servers hosting docker stacks.
Until now I have used the SMTP sending capabilities of certain docker images (eg. Watchtower) to collect information into a local fake email server called MailHog, which comes very handy.
But now that I have installed cmk, I would like to collect the email messages sent by the stacks into cmk instead.
Is that possible?
In addition to the proposal of @rprengel, you may want to take a look at the ruleset “Check Email”.
I have never used it before, but its “inline help” says:
The basic function of this check is to log in into an IMAP or POP3 mailbox to monitor whether or not the login is possible. A extended feature is, that the check can fetch all (or just some) from the mailbox and forward them as events to the Event Console.
