CMK version: Checkmk Raw Edition 2.1.0p1 OS version: linux 22.04
I installed an agent to the redis server. Now i can monitor the general information about the server but i can not manage to monitor “redis info” template (for example).
I selected enforce “redis info” template, it is now on “pending” state and can not take information about redis database.
Can someone explain to me, what should i do to monitor services like redis,mongo,nginx etc. ?
To gather such “special” information, the agent on the host has to be extended with the matching agent plugin, i.e. you have to “install” (copy to the right folder) mk_redis, nginx_status.py, … on your database server or reverse proxy.
In some cases you also need a configuration file and/or have to create a database user. Sometimes the instructions can be found as comments inside the plugin script.
Agent plugins as well as some configuration examples can be found in Setup > Agents > Linux, Solaris, AIX files
Once the plugin is installed (and configured if needed), the next service discovery for that host should offer the newly found services.
