Cannot monitor HPE MSA 2050 arrays
**CMK version:2.0.0p5 (CRE)
**OS version:debian10
Hi everyone,
I recently set up a SAN MSA 2050 and successfully configured SNMP (all versions were tested). However, I am facing an issue where only the two controller interfaces and uptime are being displayed, but not the hard disks. Would anyone be able to assist me in resolving this issue? Thank you in advance for your help!
Checkmk version 2.0.0p5
Try aquire lock on /omd/sites/Toulouse/var/check_mk/license_usage/next_run
Got lock on /omd/sites/Toulouse/var/check_mk/license_usage/next_run
Try aquire lock on /omd/sites/Toulouse/var/check_mk/license_usage/history.json
Got lock on /omd/sites/Toulouse/var/check_mk/license_usage/history.json
Releasing lock on /omd/sites/Toulouse/var/check_mk/license_usage/history.json
Released lock on /omd/sites/Toulouse/var/check_mk/license_usage/history.json
Releasing lock on /omd/sites/Toulouse/var/check_mk/license_usage/next_run
Released lock on /omd/sites/Toulouse/var/check_mk/license_usage/next_run
Loading autochecks from /omd/sites/Toulouse/var/check_mk/autochecks/TO-MSA2050.mk
+ FETCHING DATA
[cpu_tracking] Start [7f63d8d5ecd0]
[SNMPFetcher] Fetch with cache settings: SNMPFileCache(base_path=PosixPath('/omd/sites/Toulouse/tmp/check_mk/data_source_cache/snmp/TO-MSA2050'), max_age=0, disabled=False, use_outdated=False, simulation=False), Cache enabled: True
Not using cache (Too old. Age is 3 sec, allowed is 0 sec)
No persisted sections loaded
  SNMP scan:
       Getting OID .1.3.6.1.2.1.1.1.0: Running 'snmpget -v2c -c ICAM -m "" -M "" -On -OQ -Oe -Ot 10.31.X.X .1.3.6.1.2.1.1.1.0'
SNMP answer: ==> ["HPE MSA 2050 SAS"]
b'HPE MSA 2050 SAS'
       Getting OID .1.3.6.1.2.1.1.2.0: Running 'snmpget -v2c -c ICAM -m "" -M "" -On -OQ -Oe -Ot 10.31.X.X .1.3.6.1.2.1.1.2.0'
SNMP answer: ==> [.1.3.6.1.4.1.11.2.51]
b'.1.3.6.1.4.1.11.2.51'
       Using cached OID .1.3.6.1.2.1.1.1.0: 'HPE MSA 2050 SAS'
   SNMP scan found                    snmp_uptime
Try aquire lock on /omd/sites/Toulouse/tmp/check_mk/snmp_scan_cache/TO-MSA2050.10.31.X.X
Got lock on /omd/sites/Toulouse/tmp/check_mk/snmp_scan_cache/TO-MSA2050.10.31.X.X
Releasing lock on /omd/sites/Toulouse/tmp/check_mk/snmp_scan_cache/TO-MSA2050.10.31.X.X
Released lock on /omd/sites/Toulouse/tmp/check_mk/snmp_scan_cache/TO-MSA2050.10.31.X.X
if64: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Running 'snmpbulkwalk -Cr10 -v2c -c ICAM -m "" -M "" -Cc -OQ -OU -On -Ot 10.31.X.X .1.3.6.1.2.1.2.2.1.1'
Running 'snmpbulkwalk -Cr10 -v2c -c ICAM -m "" -M "" -Cc -OQ -OU -On -Ot 10.31.X.X .1.3.6.1.2.1.2.2.1.2'
Running 'snmpbulkwalk -Cr10 -v2c -c ICAM -m "" -M "" -Cc -OQ -OU -On -Ot 10.31.X.X .1.3.6.1.2.1.2.2.1.3'
Running 'snmpbulkwalk -Cr10 -v2c -c ICAM -m "" -M "" -Cc -OQ -OU -On -Ot 10.31.X.X .1.3.6.1.2.1.2.2.1.5'
Running 'snmpbulkwalk -Cr10 -v2c -c ICAM -m "" -M "" -Cc -OQ -OU -On -Ot 10.31.X.X .1.3.6.1.2.1.2.2.1.8'
Running 'snmpbulkwalk -Cr10 -v2c -c ICAM -m "" -M "" -Cc -OQ -OU -On -Ot 10.31.X.X .1.3.6.1.2.1.31.1.1.1.6'
Running 'snmpbulkwalk -Cr10 -v2c -c ICAM -m "" -M "" -Cc -OQ -OU -On -Ot 10.31.X.X .1.3.6.1.2.1.31.1.1.1.7'
Running 'snmpbulkwalk -Cr10 -v2c -c ICAM -m "" -M "" -Cc -OQ -OU -On -Ot 10.31.X.X .1.3.6.1.2.1.31.1.1.1.8'
Running 'snmpbulkwalk -Cr10 -v2c -c ICAM -m "" -M "" -Cc -OQ -OU -On -Ot 10.31.X.X .1.3.6.1.2.1.31.1.1.1.9'
Running 'snmpbulkwalk -Cr10 -v2c -c ICAM -m "" -M "" -Cc -OQ -OU -On -Ot 10.31.X.X .1.3.6.1.2.1.2.2.1.13'
Running 'snmpbulkwalk -Cr10 -v2c -c ICAM -m "" -M "" -Cc -OQ -OU -On -Ot 10.31.X.X .1.3.6.1.2.1.2.2.1.14'
Running 'snmpbulkwalk -Cr10 -v2c -c ICAM -m "" -M "" -Cc -OQ -OU -On -Ot 10.31.X.X .1.3.6.1.2.1.31.1.1.1.10'
Running 'snmpbulkwalk -Cr10 -v2c -c ICAM -m "" -M "" -Cc -OQ -OU -On -Ot 10.31.X.X .1.3.6.1.2.1.31.1.1.1.11'
Running 'snmpbulkwalk -Cr10 -v2c -c ICAM -m "" -M "" -Cc -OQ -OU -On -Ot 10.31.X.X .1.3.6.1.2.1.31.1.1.1.12'
Running 'snmpbulkwalk -Cr10 -v2c -c ICAM -m "" -M "" -Cc -OQ -OU -On -Ot 10.31.X.X .1.3.6.1.2.1.31.1.1.1.13'
Running 'snmpbulkwalk -Cr10 -v2c -c ICAM -m "" -M "" -Cc -OQ -OU -On -Ot 10.31.X.X .1.3.6.1.2.1.2.2.1.19'
Running 'snmpbulkwalk -Cr10 -v2c -c ICAM -m "" -M "" -Cc -OQ -OU -On -Ot 10.31.X.X .1.3.6.1.2.1.2.2.1.20'
Running 'snmpbulkwalk -Cr10 -v2c -c ICAM -m "" -M "" -Cc -OQ -OU -On -Ot 10.31.X.X .1.3.6.1.2.1.2.2.1.21'
Running 'snmpbulkwalk -Cr10 -v2c -c ICAM -m "" -M "" -Cc -OQ -OU -On -Ot 10.31.X.X .1.3.6.1.2.1.31.1.1.1.18'
Running 'snmpbulkwalk -Cr10 -v2c -c ICAM -m "" -M "" -Cc -OQ -OU -On -Ot 10.31.X.X .1.3.6.1.2.1.2.2.1.6'
Running 'snmpbulkwalk -Cr10 -v2c -c ICAM -m "" -M "" -Cc -OQ -OU -On -Ot 10.31.X.X .1.3.6.1.2.1.31.1.1.1.15'
Running 'snmpbulkwalk -Cr10 -v2c -c ICAM -m "" -M "" -Cc -OQ -OU -On -Ot 10.31.X.X .1.3.6.1.2.1.1.1'
Running 'snmpbulkwalk -Cr10 -v2c -c ICAM -m "" -M "" -Cc -OQ -OU -On -Ot 10.31.X.X .1.3.6.1.2.1.1.4'
Running 'snmpbulkwalk -Cr10 -v2c -c ICAM -m "" -M "" -Cc -OQ -OU -On -Ot 10.31.X.X .1.3.6.1.2.1.1.5'
Running 'snmpbulkwalk -Cr10 -v2c -c ICAM -m "" -M "" -Cc -OQ -OU -On -Ot 10.31.X.X .1.3.6.1.2.1.1.6'
Running 'snmpbulkwalk -Cr10 -v2c -c ICAM -m "" -M "" -Cc -OQ -OU -On -Ot 10.31.X.X .1.3.6.1.2.1.1.3'
Running 'snmpbulkwalk -Cr10 -v2c -c ICAM -m "" -M "" -Cc -OQ -OU -On -Ot 10.31.X.X .1.3.6.1.2.1.25.1.1'
Write data to cache file /omd/sites/Toulouse/tmp/check_mk/data_source_cache/snmp/checking/TO-MSA2050
Try aquire lock on /omd/sites/Toulouse/tmp/check_mk/data_source_cache/snmp/checking/TO-MSA2050
Got lock on /omd/sites/Toulouse/tmp/check_mk/data_source_cache/snmp/checking/TO-MSA2050
Releasing lock on /omd/sites/Toulouse/tmp/check_mk/data_source_cache/snmp/checking/TO-MSA2050
Released lock on /omd/sites/Toulouse/tmp/check_mk/data_source_cache/snmp/checking/TO-MSA2050
[cpu_tracking] Stop [7f63d8dXXXXX - Snapshot(process=posix.times_result(user=0.050000000000000044, system=0.06, children_user=0.06, children_system=0.05, elapsed=1.330000001937151))]
[cpu_tracking] Start [7f63d8d5e820]
No piggyback files for 'TO-MSA2050'. Skip processing.
No piggyback files for '10.31.X.X'. Skip processing.
[PiggybackFetcher] Fetch with cache settings: NoCache(base_path=PosixPath('/omd/sites/Toulouse/tmp/check_mk/data_source_cache/piggyback/TO-MSA2050'), max_age=0, disabled=False, use_outdated=False, simulation=False), Cache enabled: False
Not writing data to cache file (Cache usage disabled)
[cpu_tracking] Stop [7f63d8dXXXXX - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))]
[cpu_tracking] Start [7f63d8e5fd90]
+ PARSE FETCHER RESULTS
  -> Add sections: ['if64', 'snmp_info', 'snmp_uptime']
  -> Add sections: []
Received no piggyback data
Loading item states
Try aquire lock on /omd/sites/Toulouse/tmp/check_mk/counters/TO-MSA2050
Got lock on /omd/sites/Toulouse/tmp/check_mk/counters/TO-MSA2050
Releasing lock on /omd/sites/Toulouse/tmp/check_mk/counters/TO-MSA2050
Released lock on /omd/sites/Toulouse/tmp/check_mk/counters/TO-MSA2050
Interface 002        [eth0], (up), MAC: 00:C0:FF:XX:XX:XX, Speed: 1 GBit/s, In: 1.22 kB/s (<0.01%), Out: 1.78 kB/s (<0.01%)
Interface 003        [mcmc], (up), MAC: 02:C0:FF:XX:XX:XX, Speed: unknown, In: 123 B/s, Out: 92.3 B/s
SNMP Info            TO-MSA2050, Salle serveurs BATK, Administrateur
Uptime               Up since Feb 11 2023 23:49:58, Uptime: 1 day 16 hours
[cpu_tracking] Stop [7f63d8eXXXXX - Snapshot(process=posix.times_result(user=0.010000000000000009, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.009999997913837433))]
[snmp] Success, execution time 1.3 sec | execution_time=1.340 user_time=0.060 system_time=0.060 children_user_time=0.060 children_system_time=0.050 cmk_time_snmp=1.110 cmk_time_agent=0.000
The hardware status cannot be monitored with SNMP. You need to configure the special agent for HPE MSA devices.
→ rule “HP MSA via Web Interface”
If you setup an read only account and use this account with the special agent, you should see a little bit more than the three services.
That worked very well ! thanks a lot
Hi @Ershad
welcome to the forum. I am glad you got your problem solved quickly.
Please mark @andreas-doehler 's suggestion as a solution. That makes it easier for others to find it.
Thanks
Elias
