I installed it and from what I can tell that worked as it should:
OMD[Home]:~$ mkp list amavis
/omd/sites/Home/local/share/check_mk/checks/amavis
/omd/sites/Home/local/share/check_mk/agents/bakery/amavis
/omd/sites/Home/local/share/check_mk/agents/plugins/amavis
/omd/sites/Home/local/share/check_mk/web/plugins/metrics/amavis.py
/omd/sites/Home/local/share/check_mk/web/plugins/wato/agent_bakery_amavis.py
/omd/sites/Home/local/share/check_mk/web/plugins/wato/check_parameters_amavis.py
/omd/sites/Home/local/share/check_mk/web/plugins/perfometer/amavis.py
Then I copied the amavis plugin to the server running amavis. And when I manually connect from the command line I can see that it does generate output:
OMD[Home]:~$ ssh check_mk@nami /usr/bin/check_mk_agent
[ps]
[agent]
entropy STR gDYT7-sZQzmTANy6jJcotyG0
sysContact STR
sysDescr STR amavisd-new-2.11.1 (20181009)
sysLocation STR
sysName STR mail.wevers.tv
sysObjectID OID 1.3.6.1.4.1.15312.2
sysUpTime TimeTicks 1446298167 (167 days, 9:29:41.67)
ContentBadHdrMsgs 1 0/h 0.7 % (InMsgs)
ContentBadHdrMsgsInbound 1 0/h 0.7 % (InMsgsInbound)
ContentCleanMsgs 91 0/h 62.3 % (InMsgs)
ContentCleanMsgsInbound 83 0/h 60.1 % (InMsgsInbound)
However, the service does not appear for this client. So obviously I’m missing something. Question is, what am I missing?
Thanks, I double checked. I guess some strange formatting occurred in the forum markup. I double checked and the <<<amavis>>> tag is really there:
<<<amavis>>>
[ps]
[agent]
sysContact STR
sysLocation STR
sysUpTime TimeTicks 1528346397 (176 days, 21:24:23.97)
Plain copy&paste here in the forum tries to interpret the inner <...> as HTML tags unless you format them as Preformatted text (using the </> icon above the text input area or the keyboard shortcut Ctrl-Shift-C).
