CMK version: 2.0.0p12
OS version: SLES 15 SP3
OMD[test]:~$ /opt/omd/versions/2.0.0p12.cre/bin/cmk --debug -vvn check-mk
Checkmk version 2.0.0p12
Trying to acquire lock on /omd/sites/test/var/check_mk/license_usage/next_run
Got lock on /omd/sites/test/var/check_mk/license_usage/next_run
Trying to acquire lock on /omd/sites/test/var/check_mk/license_usage/history.json
Got lock on /omd/sites/test/var/check_mk/license_usage/history.json
Releasing lock on /omd/sites/test/var/check_mk/license_usage/history.json
Released lock on /omd/sites/test/var/check_mk/license_usage/history.json
Releasing lock on /omd/sites/test/var/check_mk/license_usage/next_run
Released lock on /omd/sites/test/var/check_mk/license_usage/next_run
Updating IPv4 DNS cache for check-mk: 10.201.25.252
Trying to acquire lock on /omd/sites/test/var/check_mk/ipaddresses.cache
Got lock on /omd/sites/test/var/check_mk/ipaddresses.cache
Releasing lock on /omd/sites/test/var/check_mk/ipaddresses.cache
Released lock on /omd/sites/test/var/check_mk/ipaddresses.cache
+ FETCHING DATA
[cpu_tracking] Start [7f47e3bbdd00]
No piggyback files for 'check-mk'. Skip processing.
No piggyback files for '10.201.25.252'. Skip processing.
[PiggybackFetcher] Fetch with cache settings: NoCache(base_path=PosixPath('/omd/sites/test/tmp/check_mk/data_source_cache/piggyback/check-mk'), max_age=MaxAge(checking=0, discovery=120, inventory=120), disabled=False, use_outdated=False, simulation=False)
[cpu_tracking] Stop [7f47e3bbdd00 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))]
[cpu_tracking] Start [7f47e3bbdfa0]
+ PARSE FETCHER RESULTS
No persisted sections loaded
-> Add sections: []
Received no piggyback data
Loading item states
Trying to acquire lock on /omd/sites/test/tmp/check_mk/counters/check-mk
Got lock on /omd/sites/test/tmp/check_mk/counters/check-mk
Releasing lock on /omd/sites/test/tmp/check_mk/counters/check-mk
Released lock on /omd/sites/test/tmp/check_mk/counters/check-mk
[cpu_tracking] Stop [7f47e3bbdfa0 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.009999997913837433))]
execution time 0.0 sec | execution_time=0.010 user_time=0.000 system_time=0.000 children_user_time=0.000 children_system_time=0.000 cmk_time_agent=0.000
I connected checkmk to our Windows AD. Testing the connection is fine.
I can login with a user account which is configured in checkmk in
Setup ==> Users ==> [LDAP connections] ==> Edit LDAP connection.
I also configured there a group with several users who should have access, but login with these users failed. The group is of course configured in AD.
Any ideas ?
Thanks.
Bernd
