Got time again to test. I disabled the removed the tmpfs parameter for testing. No change…
The container comes up like this:
### CREATING SITE 'cmk'
Adding /opt/omd/sites/cmk/tmp to /etc/fstab.
Going to set TMPFS to off.
Preparing tmp directory /omd/sites/cmk/tmp...Generating configuration for core (type cmc)...
WARNING: The number of configured checkers is higher than the number of available CPUs. To avoid unnecessary context switches, the number of checkers should be limited to the number of CPUs. Recommended number of checkers: 2
Starting full compilation for all hosts Creating global helper config...OK
Creating cmc protobuf configuration...OK
Updating core configuration...
Executing post-create script "01_create-sample-config.py"...OK
Created new site cmk with version 2.2.0p4.cce.
The site can be started with omd start cmk.
The default web UI is available at http://faa2d4649724/cmk/
The admin user for the web applications is cmkadmin with password: J78HHlQ1
For command line administration of the site, log in with 'omd su cmk'.
After logging in, you can change the password for cmkadmin with 'cmk-passwd cmkadmin'.
WARNING: You have to execute 'omd update-apache-config cmk' as root to update and apply the configuration of the system apache.
### STARTING XINETD
* Starting internet superserver xinetd
...done.
### STARTING SITE
Preparing tmp directory /omd/sites/cmk/tmp...Starting agent-receiver...OK
Starting mkeventd...OK
Starting liveproxyd...OK
Starting mknotifyd...OK
Starting rrdcached...OK
Starting cmc...OK
Starting apache...OK
Starting dcd...OK
Starting redis...OK
Initializing Crontab...OK
### STARTING CRON
### CONTAINER STARTED
and the whole system is slow af. The cmk website does not even open and the cpu usage was around 20% per thread. I also noticed many same processes within container:
:~# docker exec -it checkmk bash
root@faa2d4649724:/# ps -eF
UID PID PPID C SZ RSS PSR STIME TTY TIME CMD
root 1 0 0 1090 516 0 18:00 ? 00:00:00 /bin/bash /docker-entrypoint.sh
root 641 1 0 1477 508 0 18:04 ? 00:00:00 /usr/sbin/xinetd -pidfile /run/xinetd.pid -stayalive -inetd_compat -inetd_ipv6
cmk 681 1 0 9494 21760 0 18:04 ? 00:00:01 gunicorn: master [agent_receiver.main:main_app()]
cmk 711 681 0 14366 38216 0 18:05 ? 00:00:11 gunicorn: worker [agent_receiver.main:main_app()]
cmk 844 1 0 44646 26128 0 18:05 ? 00:00:02 python3 /omd/sites/cmk/bin/mkeventd
cmk 863 1 0 8480 17104 1 18:05 ? 00:00:02 liveproxyd[master]
cmk 885 1 0 7542 13648 0 18:05 ? 00:00:03 python3 /omd/sites/cmk/bin/mknotifyd
cmk 891 1 0 16160 3076 1 18:05 ? 00:00:00 /omd/sites/cmk/bin/rrdcached -t 4 -w 3600 -z 1800 -f 7200 -s cmk -m 660 -l unix:/omd/sites/cmk/tmp/run/rrdcached.sock -p /omd/sites/cmk/tmp/rrdcached.pid -j /omd/sites/cmk/v
cmk 913 1 0 286114 7400 0 18:05 ? 00:00:03 /omd/sites/cmk/bin/cmc /omd/sites/cmk/var/check_mk/core/config.pb
cmk 937 913 1 38624 84580 0 18:05 ? 00:00:22 python3 /omd/sites/cmk/bin/cmk --create-rrd --keepalive
cmk 939 913 1 27213 83884 0 18:05 ? 00:00:22 python3 /omd/sites/cmk/bin/cmk --handle-alerts --keepalive
cmk 943 913 0 2327 248 1 18:05 ? 00:00:00 /omd/sites/cmk/lib/cmc/checkhelper
cmk 944 913 0 2327 248 0 18:05 ? 00:00:00 /omd/sites/cmk/lib/cmc/checkhelper
cmk 945 913 0 2327 248 1 18:05 ? 00:00:00 /omd/sites/cmk/lib/cmc/checkhelper
cmk 946 913 0 2327 248 0 18:05 ? 00:00:00 /omd/sites/cmk/lib/cmc/checkhelper
cmk 948 913 0 2327 252 0 18:05 ? 00:00:00 /omd/sites/cmk/lib/cmc/checkhelper
cmk 949 913 1 28331 85768 1 18:05 ? 00:00:22 python3 /omd/sites/cmk/bin/cmk --checker
cmk 950 913 1 28328 85624 0 18:05 ? 00:00:22 python3 /omd/sites/cmk/bin/cmk --checker
cmk 951 913 1 28306 85848 0 18:05 ? 00:00:22 python3 /omd/sites/cmk/bin/cmk --checker
cmk 952 913 1 28306 85764 1 18:05 ? 00:00:23 python3 /omd/sites/cmk/bin/cmk --checker
cmk 954 913 1 27229 83880 0 18:05 ? 00:00:22 python3 /omd/sites/cmk/bin/cmk --keepalive --real-time-checks
cmk 955 913 0 11658 24196 0 18:05 ? 00:00:02 python3 /omd/sites/cmk/bin/fetcher
cmk 956 913 0 11658 24192 1 18:05 ? 00:00:02 python3 /omd/sites/cmk/bin/fetcher
cmk 957 913 0 11658 24192 1 18:05 ? 00:00:02 python3 /omd/sites/cmk/bin/fetcher
cmk 958 913 0 11658 24188 0 18:05 ? 00:00:02 python3 /omd/sites/cmk/bin/fetcher
cmk 960 913 0 11658 24192 1 18:05 ? 00:00:02 python3 /omd/sites/cmk/bin/fetcher
cmk 961 913 0 11658 24192 0 18:05 ? 00:00:02 python3 /omd/sites/cmk/bin/fetcher
cmk 962 913 0 11658 24192 1 18:05 ? 00:00:02 python3 /omd/sites/cmk/bin/fetcher
cmk 965 913 0 11658 24196 1 18:05 ? 00:00:02 python3 /omd/sites/cmk/bin/fetcher
cmk 966 913 0 11658 24192 0 18:05 ? 00:00:02 python3 /omd/sites/cmk/bin/fetcher
cmk 967 913 0 11658 24192 1 18:05 ? 00:00:02 python3 /omd/sites/cmk/bin/fetcher
cmk 968 913 0 11658 24192 1 18:05 ? 00:00:02 python3 /omd/sites/cmk/bin/fetcher
cmk 972 913 0 11658 24140 1 18:05 ? 00:00:02 python3 /omd/sites/cmk/bin/fetcher
cmk 973 913 0 11658 24192 0 18:05 ? 00:00:02 python3 /omd/sites/cmk/bin/fetcher
cmk 974 913 0 15016 35804 0 18:05 ? 00:00:04 python3 /omd/sites/cmk/bin/cmk --notify --keepalive
cmk 976 913 0 1276 108 0 18:05 ? 00:00:00 /omd/sites/cmk/lib/cmc/icmpsender 8 0 1000
cmk 978 913 0 2788 252 0 18:05 ? 00:00:00 /omd/sites/cmk/lib/cmc/icmpreceiver
cmk 1001 1 0 3711 3664 1 18:05 ? 00:00:00 /usr/sbin/apache2 -f /omd/sites/cmk/etc/apache/apache.conf
cmk 1004 1001 0 3705 2460 1 18:05 ? 00:00:00 /usr/sbin/apache2 -f /omd/sites/cmk/etc/apache/apache.conf
cmk 1005 1001 1 70604 193492 0 18:05 ? 00:00:39 /usr/sbin/apache2 -f /omd/sites/cmk/etc/apache/apache.conf
cmk 1063 1 0 28304 27348 1 18:06 ? 00:00:00 dcd
cmk 1069 1 0 13761 10224 0 18:07 ? 00:00:06 /omd/sites/cmk/bin/redis-server unixsocket:/omd/sites/cmk/tmp/run/redis
root 1091 1 0 971 508 0 18:07 ? 00:00:00 cron -f
root 1189 1091 0 1569 712 0 18:08 ? 00:00:00 CRON -f
cmk 1193 1189 0 1195 492 0 18:08 ? 00:00:00 /bin/bash -c . $OMD_ROOT/etc/omd/site.conf ; curl http://localhost:$CONFIG_APACHE_TCP_PORT/cmk/check_mk/run_cron.py >/dev/null 2>&1
cmk 1209 1193 0 4952 1252 1 18:08 ? 00:00:00 curl http://localhost:5000/cmk/check_mk/run_cron.py
root 1355 1091 0 1569 712 0 18:09 ? 00:00:00 CRON -f
cmk 1359 1355 0 1195 492 0 18:09 ? 00:00:00 /bin/bash -c . $OMD_ROOT/etc/omd/site.conf ; curl http://localhost:$CONFIG_APACHE_TCP_PORT/cmk/check_mk/run_cron.py >/dev/null 2>&1
cmk 1389 1359 0 4952 1256 0 18:09 ? 00:00:00 curl http://localhost:5000/cmk/check_mk/run_cron.py
root 1452 1091 0 1569 712 0 18:10 ? 00:00:00 CRON -f
cmk 1458 1452 0 1195 492 1 18:10 ? 00:00:00 /bin/bash -c . $OMD_ROOT/etc/omd/site.conf ; curl http://localhost:$CONFIG_APACHE_TCP_PORT/cmk/check_mk/run_cron.py >/dev/null 2>&1
cmk 1492 1458 0 4952 1260 1 18:10 ? 00:00:00 curl http://localhost:5000/cmk/check_mk/run_cron.py
cmk 1643 1001 1 70576 193320 1 18:10 ? 00:00:30 /usr/sbin/apache2 -f /omd/sites/cmk/etc/apache/apache.conf
cmk 1652 1 0 70604 193196 1 18:10 ? 00:00:00 /usr/sbin/apache2 -f /omd/sites/cmk/etc/apache/apache.conf
root 1654 1091 0 1569 712 1 18:11 ? 00:00:00 CRON -f
cmk 1657 1654 0 1195 492 0 18:11 ? 00:00:00 /bin/bash -c . $OMD_ROOT/etc/omd/site.conf ; curl http://localhost:$CONFIG_APACHE_TCP_PORT/cmk/check_mk/run_cron.py >/dev/null 2>&1
cmk 1674 1657 0 4952 1256 0 18:11 ? 00:00:00 curl http://localhost:5000/cmk/check_mk/run_cron.py
root 1821 1091 0 1569 712 0 18:12 ? 00:00:00 CRON -f
cmk 1823 1821 0 1195 492 0 18:12 ? 00:00:00 /bin/bash -c . $OMD_ROOT/etc/omd/site.conf ; curl http://localhost:$CONFIG_APACHE_TCP_PORT/cmk/check_mk/run_cron.py >/dev/null 2>&1
cmk 1841 1823 0 4952 1264 0 18:12 ? 00:00:00 curl http://localhost:5000/cmk/check_mk/run_cron.py
cmk 1847 1001 1 70581 193316 0 18:12 ? 00:00:29 /usr/sbin/apache2 -f /omd/sites/cmk/etc/apache/apache.conf
root 1993 1091 0 1569 712 1 18:13 ? 00:00:00 CRON -f
cmk 1995 1993 0 1195 488 0 18:13 ? 00:00:00 /bin/bash -c . $OMD_ROOT/etc/omd/site.conf ; curl http://localhost:$CONFIG_APACHE_TCP_PORT/cmk/check_mk/run_cron.py >/dev/null 2>&1
cmk 2013 1995 0 4952 1260 0 18:13 ? 00:00:00 curl http://localhost:5000/cmk/check_mk/run_cron.py
cmk 2019 1001 1 70576 193320 1 18:13 ? 00:00:29 /usr/sbin/apache2 -f /omd/sites/cmk/etc/apache/apache.conf
root 2165 1091 0 1569 712 1 18:14 ? 00:00:00 CRON -f
cmk 2168 2165 0 1195 488 1 18:14 ? 00:00:00 /bin/bash -c . $OMD_ROOT/etc/omd/site.conf ; curl http://localhost:$CONFIG_APACHE_TCP_PORT/cmk/check_mk/run_cron.py >/dev/null 2>&1
cmk 2185 2168 0 4952 1260 0 18:14 ? 00:00:00 curl http://localhost:5000/cmk/check_mk/run_cron.py
cmk 2187 1001 1 70581 193316 0 18:14 ? 00:00:30 /usr/sbin/apache2 -f /omd/sites/cmk/etc/apache/apache.conf
root 2338 1091 0 1569 712 0 18:15 ? 00:00:00 CRON -f
cmk 2344 2338 0 1195 492 1 18:15 ? 00:00:00 /bin/bash -c . $OMD_ROOT/etc/omd/site.conf ; curl http://localhost:$CONFIG_APACHE_TCP_PORT/cmk/check_mk/run_cron.py >/dev/null 2>&1
cmk 2379 2344 0 4952 1264 0 18:15 ? 00:00:00 curl http://localhost:5000/cmk/check_mk/run_cron.py
cmk 2385 1001 2 70576 193328 0 18:15 ? 00:00:31 /usr/sbin/apache2 -f /omd/sites/cmk/etc/apache/apache.conf
root 2454 1091 0 1569 712 0 18:16 ? 00:00:00 CRON -f
cmk 2459 2454 0 1195 492 1 18:16 ? 00:00:00 /bin/bash -c . $OMD_ROOT/etc/omd/site.conf ; curl http://localhost:$CONFIG_APACHE_TCP_PORT/cmk/check_mk/run_cron.py >/dev/null 2>&1
cmk 2484 2459 0 4952 1256 0 18:16 ? 00:00:00 curl http://localhost:5000/cmk/check_mk/run_cron.py
cmk 2558 1001 2 70577 193320 0 18:16 ? 00:00:29 /usr/sbin/apache2 -f /omd/sites/cmk/etc/apache/apache.conf
root 2640 1091 0 1569 712 0 18:17 ? 00:00:00 CRON -f
cmk 2646 2640 0 1195 488 0 18:17 ? 00:00:00 /bin/bash -c . $OMD_ROOT/etc/omd/site.conf ; curl http://localhost:$CONFIG_APACHE_TCP_PORT/cmk/check_mk/run_cron.py >/dev/null 2>&1
cmk 2670 2646 0 4952 1260 0 18:17 ? 00:00:00 curl http://localhost:5000/cmk/check_mk/run_cron.py
cmk 2730 1001 2 70581 193320 0 18:17 ? 00:00:29 /usr/sbin/apache2 -f /omd/sites/cmk/etc/apache/apache.conf
root 2735 1091 0 1569 712 1 18:18 ? 00:00:00 CRON -f
cmk 2739 2735 0 1195 488 0 18:18 ? 00:00:00 /bin/bash -c . $OMD_ROOT/etc/omd/site.conf ; curl http://localhost:$CONFIG_APACHE_TCP_PORT/cmk/check_mk/run_cron.py >/dev/null 2>&1
cmk 2755 2739 0 4952 1256 0 18:18 ? 00:00:00 curl http://localhost:5000/cmk/check_mk/run_cron.py
cmk 2902 1001 2 70581 193084 0 18:18 ? 00:00:30 /usr/sbin/apache2 -f /omd/sites/cmk/etc/apache/apache.conf
root 2908 1091 0 1569 712 1 18:19 ? 00:00:00 CRON -f
cmk 2911 2908 0 1195 488 1 18:19 ? 00:00:00 /bin/bash -c . $OMD_ROOT/etc/omd/site.conf ; curl http://localhost:$CONFIG_APACHE_TCP_PORT/cmk/check_mk/run_cron.py >/dev/null 2>&1
cmk 2928 2911 0 4952 1264 1 18:19 ? 00:00:00 curl http://localhost:5000/cmk/check_mk/run_cron.py
root 3074 1091 0 1569 712 1 18:20 ? 00:00:00 CRON -f
root 3075 1091 0 1569 712 0 18:20 ? 00:00:00 CRON -f
root 3076 1091 0 1569 712 0 18:20 ? 00:00:00 CRON -f
cmk 3078 3075 0 3253 4228 1 18:20 ? 00:00:00 python3 /omd/sites/cmk/bin/cmk --inventorize-marked-hosts
cmk 3079 3076 0 1195 488 0 18:20 ? 00:00:00 /bin/bash -c cmk --discover-marked-hosts >/dev/null 2>&1
cmk 3081 3074 0 1195 492 1 18:20 ? 00:00:00 /bin/bash -c . $OMD_ROOT/etc/omd/site.conf ; curl http://localhost:$CONFIG_APACHE_TCP_PORT/cmk/check_mk/run_cron.py >/dev/null 2>&1
cmk 3114 3079 0 3253 4228 0 18:20 ? 00:00:00 python3 /omd/sites/cmk/bin/cmk --discover-marked-hosts
cmk 3115 3081 0 4952 1244 0 18:20 ? 00:00:00 curl http://localhost:5000/cmk/check_mk/run_cron.py
cmk 3117 1001 0 4592 5344 1 18:20 ? 00:00:00 /usr/sbin/apache2 -f /omd/sites/cmk/etc/apache/apache.conf
root 3122 1091 0 1569 712 0 18:21 ? 00:00:00 CRON -f
root 3123 1091 0 1569 712 0 18:21 ? 00:00:00 CRON -f
cmk 3124 3122 0 1569 484 0 18:21 ? 00:00:00 CRON -f
cmk 3125 3123 0 1569 484 0 18:21 ? 00:00:00 CRON -f
root 3132 1 0 9139 18388 0 18:21 ? 00:00:00 /omd/versions/2.2.0p4.cce/bin/python3 /usr/bin/omd status
root 3133 1091 0 1569 712 1 18:22 ? 00:00:00 CRON -f
root 3134 1091 0 1569 712 0 18:22 ? 00:00:00 CRON -f
cmk 3135 3133 0 1569 484 1 18:22 ? 00:00:00 CRON -f
cmk 3136 3134 0 1569 484 0 18:22 ? 00:00:00 CRON -f
root 3144 1 0 9139 18396 1 18:22 ? 00:00:00 /omd/versions/2.2.0p4.cce/bin/python3 /usr/bin/omd status
root 3145 1091 0 1569 712 0 18:23 ? 00:00:00 CRON -f
root 3146 1091 0 1569 712 1 18:23 ? 00:00:00 CRON -f
cmk 3147 3145 0 1569 484 0 18:23 ? 00:00:00 CRON -f
cmk 3148 3146 0 1569 484 1 18:23 ? 00:00:00 CRON -f
root 3149 0 0 1156 832 1 18:23 pts/0 00:00:00 bash
root 3166 1 0 9139 18396 1 18:23 ? 00:00:00 /omd/versions/2.2.0p4.cce/bin/python3 /usr/bin/omd status
root 3170 1091 0 1569 712 0 18:24 ? 00:00:00 CRON -f
root 3171 1091 0 1569 712 0 18:24 ? 00:00:00 CRON -f
cmk 3172 3170 0 1569 484 0 18:24 ? 00:00:00 CRON -f
cmk 3173 3171 0 1569 484 1 18:24 ? 00:00:00 CRON -f
root 3182 1 0 9139 18388 0 18:24 ? 00:00:00 /omd/versions/2.2.0p4.cce/bin/python3 /usr/bin/omd status
root 3183 1091 0 1569 712 1 18:25 ? 00:00:00 CRON -f
root 3184 1091 0 1569 712 1 18:25 ? 00:00:00 CRON -f
root 3185 1091 0 1569 712 0 18:25 ? 00:00:00 CRON -f
root 3186 1091 0 1569 712 1 18:25 ? 00:00:00 CRON -f
cmk 3187 3183 0 1569 484 0 18:25 ? 00:00:00 CRON -f
cmk 3188 3186 0 1569 484 0 18:25 ? 00:00:00 CRON -f
cmk 3189 3184 0 1569 484 1 18:25 ? 00:00:00 CRON -f
cmk 3190 3185 0 1569 484 0 18:25 ? 00:00:00 CRON -f
root 3191 3149 0 1891 1260 1 18:25 pts/0 00:00:05 top
root 3199 1 0 9139 18400 1 18:25 ? 00:00:00 /omd/versions/2.2.0p4.cce/bin/python3 /usr/bin/omd status
root 3200 1091 0 1569 712 1 18:26 ? 00:00:00 CRON -f
root 3201 1091 0 1569 712 0 18:26 ? 00:00:00 CRON -f
cmk 3202 3200 0 1569 484 1 18:26 ? 00:00:00 CRON -f
cmk 3203 3201 0 1569 484 1 18:26 ? 00:00:00 CRON -f
root 3210 1 0 9139 18356 1 18:26 ? 00:00:00 /omd/versions/2.2.0p4.cce/bin/python3 /usr/bin/omd status
root 3211 1091 0 1569 712 1 18:27 ? 00:00:00 CRON -f
root 3212 1091 0 1569 712 1 18:27 ? 00:00:00 CRON -f
cmk 3213 3212 0 1569 484 1 18:27 ? 00:00:00 CRON -f
cmk 3214 3211 0 1569 484 1 18:27 ? 00:00:00 CRON -f
root 3215 1091 0 1569 712 0 18:28 ? 00:00:00 CRON -f
root 3216 1091 0 1569 712 0 18:28 ? 00:00:00 CRON -f
cmk 3217 3215 0 1569 484 0 18:28 ? 00:00:00 CRON -f
cmk 3218 3216 0 1569 484 0 18:28 ? 00:00:00 CRON -f
root 3219 1091 0 1569 712 0 18:29 ? 00:00:00 CRON -f
root 3220 1091 0 1569 712 1 18:29 ? 00:00:00 CRON -f
cmk 3221 3220 0 1569 484 1 18:29 ? 00:00:00 CRON -f
cmk 3222 3219 0 1569 484 1 18:29 ? 00:00:00 CRON -f
root 3223 1091 0 1569 712 0 18:30 ? 00:00:00 CRON -f
root 3224 1091 0 1569 712 1 18:30 ? 00:00:00 CRON -f
root 3225 1091 0 1569 712 1 18:30 ? 00:00:00 CRON -f
root 3226 1091 0 1569 712 1 18:30 ? 00:00:00 CRON -f
cmk 3227 3223 0 1569 484 0 18:30 ? 00:00:00 CRON -f
cmk 3228 3225 0 1569 484 1 18:30 ? 00:00:00 CRON -f
cmk 3229 3224 0 1569 484 0 18:30 ? 00:00:00 CRON -f
cmk 3230 3226 0 1569 484 0 18:30 ? 00:00:00 CRON -f
root 3231 1091 0 1569 712 1 18:31 ? 00:00:00 CRON -f
root 3232 1091 0 1569 712 0 18:31 ? 00:00:00 CRON -f
cmk 3233 3231 0 1569 484 1 18:31 ? 00:00:00 CRON -f
cmk 3234 3232 0 1569 484 1 18:31 ? 00:00:00 CRON -f
root 3235 1091 0 1569 716 1 18:32 ? 00:00:00 CRON -f
root 3236 1091 0 1569 716 1 18:32 ? 00:00:00 CRON -f
cmk 3237 3236 0 1569 484 1 18:32 ? 00:00:00 CRON -f
cmk 3238 3235 0 1569 484 1 18:32 ? 00:00:00 CRON -f
root 3239 1091 0 1569 716 1 18:33 ? 00:00:00 CRON -f
root 3240 1091 0 1569 716 0 18:33 ? 00:00:00 CRON -f
cmk 3241 3239 0 1569 484 1 18:33 ? 00:00:00 CRON -f
cmk 3242 3240 0 1569 484 0 18:33 ? 00:00:00 CRON -f
root 3243 0 0 1156 760 1 18:33 pts/1 00:00:00 bash
root 3251 0 0 1156 804 1 18:33 pts/2 00:00:00 bash
root 3260 1091 0 1569 716 1 18:34 ? 00:00:00 CRON -f
root 3261 1091 0 1569 716 1 18:34 ? 00:00:00 CRON -f
cmk 3262 3261 0 1569 484 1 18:34 ? 00:00:00 CRON -f
cmk 3263 3260 0 1569 484 1 18:34 ? 00:00:00 CRON -f
root 3265 3251 0 1156 580 0 18:34 pts/2 00:00:00 bash
root 3266 1091 0 1569 716 1 18:35 ? 00:00:00 CRON -f
root 3267 1091 0 1569 716 0 18:35 ? 00:00:00 CRON -f
root 3268 1091 0 1569 716 0 18:35 ? 00:00:00 CRON -f
root 3269 1091 0 1569 716 0 18:35 ? 00:00:00 CRON -f
cmk 3270 3269 0 1569 484 0 18:35 ? 00:00:00 CRON -f
cmk 3271 3266 0 1569 484 0 18:35 ? 00:00:00 CRON -f
cmk 3272 3267 0 1569 484 0 18:35 ? 00:00:00 CRON -f
cmk 3273 3268 0 1569 484 0 18:35 ? 00:00:00 CRON -f
root 3274 1091 0 1569 716 1 18:36 ? 00:00:00 CRON -f
root 3275 1091 0 1569 716 1 18:36 ? 00:00:00 CRON -f
cmk 3276 3275 0 1569 484 1 18:36 ? 00:00:00 CRON -f
cmk 3277 3274 0 1569 484 1 18:36 ? 00:00:00 CRON -f
root 3278 1091 0 1569 832 0 18:37 ? 00:00:00 CRON -f
root 3279 1091 0 1569 840 1 18:37 ? 00:00:00 CRON -f
cmk 3280 3279 0 1569 484 0 18:37 ? 00:00:00 CRON -f
cmk 3281 3278 0 1569 484 1 18:37 ? 00:00:00 CRON -f
root 3282 1091 0 1569 864 1 18:38 ? 00:00:00 CRON -f
root 3283 1091 0 1569 864 0 18:38 ? 00:00:00 CRON -f
cmk 3284 3282 0 1569 484 1 18:38 ? 00:00:00 CRON -f
cmk 3285 3283 0 1569 484 1 18:38 ? 00:00:00 CRON -f
root 3287 1091 0 1569 852 1 18:39 ? 00:00:00 CRON -f
root 3288 1091 0 1569 856 1 18:39 ? 00:00:00 CRON -f
cmk 3289 3287 0 1569 484 1 18:39 ? 00:00:00 CRON -f
cmk 3291 3288 0 1569 484 0 18:39 ? 00:00:00 CRON -f
root 3332 0 0 1156 2624 0 18:39 pts/3 00:00:00 bash
root 3340 1091 0 1569 3368 1 18:40 ? 00:00:00 CRON -f
root 3341 1091 0 1569 3368 1 18:40 ? 00:00:00 CRON -f
root 3342 1091 0 1569 3340 1 18:40 ? 00:00:00 CRON -f
root 3343 1091 0 1569 3336 1 18:40 ? 00:00:00 CRON -f
cmk 3344 3341 0 1569 484 1 18:40 ? 00:00:00 CRON -f
cmk 3345 3343 0 1569 484 1 18:40 ? 00:00:00 CRON -f
cmk 3346 3342 0 1569 484 1 18:40 ? 00:00:00 CRON -f
cmk 3347 3340 0 1569 484 0 18:40 ? 00:00:00 CRON -f
Any attemp to read from /omd is very slow. I dont know what is going on.
As already noted: the previous docker versions (2.1.x) were working.
Docker also showing cmk as Up 47 minutes (unhealthy).
docker inspect - if this helps:
:~# docker inspect checkmk
"Id": "faa2d464972469bf4f8922d33045712cc62d2390503107b106bb2d9f014e6de5",
"Created": "2023-07-04T16:00:51.506752429Z",
"Path": "/docker-entrypoint.sh",
"Args": [],
"State": {
"Status": "running",
"Running": true,
"Paused": false,
"Restarting": false,
"OOMKilled": false,
"Dead": false,
"Pid": 24899,
"ExitCode": 0,
"Error": "",
"StartedAt": "2023-07-04T16:00:54.617445009Z",
"FinishedAt": "0001-01-01T00:00:00Z",
"Health": {
"Status": "unhealthy",
"FailingStreak": 39,
"Log": [
"Start": "2023-07-04T18:43:35.184465387+02:00",
"End": "2023-07-04T18:43:40.741751603+02:00",
"ExitCode": -1,
"Output": "Health check exceeded timeout (5s)"
"Start": "2023-07-04T18:44:43.724190762+02:00",
"End": "2023-07-04T18:44:48.922808115+02:00",
"ExitCode": -1,
"Start": "2023-07-04T18:45:51.81907558+02:00",
"End": "2023-07-04T18:45:58.998049001+02:00",
"ExitCode": -1,
"Start": "2023-07-04T18:47:12.419566162+02:00",
"End": "2023-07-04T18:47:12.684159746+02:00",
"ExitCode": -1,
"Output": "OCI runtime exec failed: exec failed: unable to start container process: error executing setns process: exit status 1: unknown"
"Start": "2023-07-04T18:48:12.87013021+02:00",
"End": "2023-07-04T18:48:12.98163281+02:00",
"ExitCode": -1,
"Image": "sha256:08187f5a9ba5aae91db8b1a9545e1b0e6ef0cc3e1af1f386d02f8f001023bb62",
"ResolvConfPath": "/var/lib/docker/containers/faa2d464972469bf4f8922d33045712cc62d2390503107b106bb2d9f014e6de5/resolv.conf",
"HostnamePath": "/var/lib/docker/containers/faa2d464972469bf4f8922d33045712cc62d2390503107b106bb2d9f014e6de5/hostname",
"HostsPath": "/var/lib/docker/containers/faa2d464972469bf4f8922d33045712cc62d2390503107b106bb2d9f014e6de5/hosts",
"LogPath": "/var/lib/docker/containers/faa2d464972469bf4f8922d33045712cc62d2390503107b106bb2d9f014e6de5/faa2d464972469bf4f8922d33045712cc62d2390503107b106bb2d9f014e6de5-json.log",
"Name": "/checkmk",
"RestartCount": 0,
"Driver": "btrfs",
"Platform": "linux",
"MountLabel": "",
"ProcessLabel": "",
"AppArmorProfile": "",
"ExecIDs": [
"14b8245a04dff8711c1031e8cdf7eaa0236e18208893408fc28ab3f5e3b17cb7"
"HostConfig": {
"Binds": [
"/mnt/user/appdata/cmk:/omd/sites:rw",
"/etc/localtime:/etc/localtime:ro"
"ContainerIDFile": "",
"LogConfig": {
"Type": "json-file",
"Config": {
"max-file": "1",
"max-size": "50m"
"NetworkMode": "br0",
"PortBindings": {},
"RestartPolicy": {
"Name": "no",
"MaximumRetryCount": 0
"AutoRemove": false,
"VolumeDriver": "",
"VolumesFrom": null,
"CapAdd": null,
"CapDrop": null,
"CgroupnsMode": "private",
"Dns": [],
"DnsOptions": [],
"DnsSearch": [],
"ExtraHosts": null,
"GroupAdd": null,
"IpcMode": "private",
"Cgroup": "",
"Links": null,
"OomScoreAdj": 0,
"PidMode": "",
"Privileged": false,
"PublishAllPorts": false,
"ReadonlyRootfs": false,
"SecurityOpt": null,
"UTSMode": "",
"UsernsMode": "",
"ShmSize": 67108864,
"Runtime": "runc",
"ConsoleSize": [
0,
0
"Isolation": "",
"CpuShares": 0,
"Memory": 0,
"NanoCpus": 0,
"CgroupParent": "",
"BlkioWeight": 0,
"BlkioWeightDevice": [],
"BlkioDeviceReadBps": null,
"BlkioDeviceWriteBps": null,
"BlkioDeviceReadIOps": null,
"BlkioDeviceWriteIOps": null,
"CpuPeriod": 0,
"CpuQuota": 0,
"CpuRealtimePeriod": 0,
"CpuRealtimeRuntime": 0,
"CpusetCpus": "",
"CpusetMems": "",
"Devices": [],
"DeviceCgroupRules": null,
"DeviceRequests": null,
"KernelMemory": 0,
"KernelMemoryTCP": 0,
"MemoryReservation": 0,
"MemorySwap": 0,
"MemorySwappiness": null,
"OomKillDisable": null,
"PidsLimit": null,
"Ulimits": null,
"CpuCount": 0,
"CpuPercent": 0,
"IOMaximumIOps": 0,
"IOMaximumBandwidth": 0,
"MaskedPaths": [
"/proc/asound",
"/proc/acpi",
"/proc/kcore",
"/proc/keys",
"/proc/latency_stats",
"/proc/timer_list",
"/proc/timer_stats",
"/proc/sched_debug",
"/proc/scsi",
"/sys/firmware"
"ReadonlyPaths": [
"/proc/bus",
"/proc/fs",
"/proc/irq",
"/proc/sys",
"/proc/sysrq-trigger"
"GraphDriver": {
"Data": null,
"Name": "btrfs"
"Mounts": [
"Type": "bind",
"Source": "/mnt/user/appdata/cmk",
"Destination": "/omd/sites",
"Mode": "rw",
"RW": true,
"Propagation": "rprivate"
"Type": "bind",
"Source": "/etc/localtime",
"Destination": "/etc/localtime",
"Mode": "ro",
"RW": false,
"Config": {
"Hostname": "faa2d4649724",
"Domainname": "",
"User": "",
"AttachStdin": false,
"AttachStdout": false,
"AttachStderr": false,
"ExposedPorts": {
"5000/tcp": {},
"6557/tcp": {}
"Tty": false,
"OpenStdin": false,
"StdinOnce": false,
"Env": [
"TZ=Europe/Berlin",
"HOST_OS=Unraid",
"HOST_HOSTNAME=Playtime",
"HOST_CONTAINERNAME=checkmk",
"PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin",
"CMK_SITE_ID=cmk",
"CMK_LIVESTATUS_TCP=",
"CMK_PASSWORD=",
"MAIL_RELAY_HOST=",
"CMK_CONTAINERIZED=TRUE"
"Cmd": null,
"Healthcheck": {
"Test": [
"CMD-SHELL",
"omd status || exit 1"
"Interval": 60000000000,
"Timeout": 5000000000
"Image": "checkmk/check-mk-cloud:2.2.0p4",
"Volumes": null,
"WorkingDir": "",
"Entrypoint": [
"OnBuild": null,
"Labels": {
"maintainer": "feedback@checkmk.com",
"net.unraid.docker.managed": "dockerman",
"org.opencontainers.image.description": "Checkmk is a leading tool for Infrastructure & Application Monitoring",
"org.opencontainers.image.source": "https://github.com/checkmk/checkmk",
"org.opencontainers.image.title": "Checkmk",
"org.opencontainers.image.url": "https://checkmk.com/",
"org.opencontainers.image.vendor": "Checkmk GmbH",
"org.opencontainers.image.version": "2.2.0p4"
"NetworkSettings": {
"Bridge": "",
"SandboxID": "bbd801e7323107ae29910bdf6908c6a6126e0b87be72d7e78e9102f291e82887",
"HairpinMode": false,
"LinkLocalIPv6Address": "",
"LinkLocalIPv6PrefixLen": 0,
"Ports": {},
"SandboxKey": "/var/run/docker/netns/bbd801e73231",
"SecondaryIPAddresses": null,
"SecondaryIPv6Addresses": null,
"EndpointID": "",
"Gateway": "",
"GlobalIPv6Address": "",
"GlobalIPv6PrefixLen": 0,
"IPAddress": "",
"IPPrefixLen": 0,
"IPv6Gateway": "",
"MacAddress": "",
"Networks": {
"br0": {
"IPAMConfig": {
"IPv4Address": "192.168.178.17"
"Links": null,
"Aliases": [
"faa2d4649724"
"NetworkID": "4a5317686d0d84b8a1d267ed444a874967ca0be40ff4f6e8629ee3685f011822",
"EndpointID": "dd772f63dd73256a043a965d95d244fa0e78a29eccad662138629e0e66da573e",
"Gateway": "192.168.178.1",
"IPAddress": "192.168.178.17",
"IPPrefixLen": 24,
"IPv6Gateway": "xxxxx",
"GlobalIPv6Address": "xxxxxx",
"GlobalIPv6PrefixLen": 64,
"MacAddress": "",
"DriverOpts": null
