I’m creating a custom spezial agent and I use predictive monitoring for it. I was wondering if it is possible to change the graph of the prediction, like it is possible for other graphs.
For my other graphs I can mkae the settings in my graphing file like this:
metric_data_domain_post_compression_in_bytes = Metric(
name="post_compression_in_bytes",
title=Title("post compression in bytes"),
unit = Unit(DecimalNotation("")),
color=Color.BLUE,
and it works.
I tried to use different names for the prediction graph I can’t make that work.
in the rrd info file the name of the graph is predict_post_compression_in_bytes
but it does not change the graph.
So the question is:
Is it even possible to change the look of a prediction graph, since I did not create it myself? It was created by the “prediction API” or whatever.
here is the code from my agent_based file for the prediction:
yield from check_levels(
value=post_compression_in_bytes_value,
levels_upper=params.get('levels_post_compression_in_bytes_upper'),
metric_name='post_compression_in_bytes',
render_func=str,
label='post_compression_in_bytes',
Thanks and BR
Andre
