Changes can not be applied due to: 'Internal automation error: Error running automation call restart'
CMK version: 2.3.0p30
OS version: Linux (oracle 9.5)
We are having some issues with a specific site in our distributed monitoring. The site shows the following error in our pending changes overview. We are using dynamic host management with enabled automatic change activation.
Restarting the site and immediately activating the changes manually does work, but this error will come up again and no changes are activated automatically.
Started at: 17:54:50. Finished at: 17:56:03.
Got invalid data:
Internal automation error: Error running automation call restart (exit code 1), error:
An error occurred: Other restart currently in progress. Aborting.
  File "/omd/sites/az_de_s1/lib/python3/cmk/gui/wato/pages/automation.py", line 236, in _execute_automation_command
    response.set_data(repr(automation.execute(automation.get_request())))
  File "/omd/sites/az_de_s1/lib/python3/cmk/gui/wato/pages/activate_changes.py", line 1057, in execute
    return activate_changes.execute_activate_changes(
  File "/omd/sites/az_de_s1/lib/python3/cmk/gui/watolib/activate_changes.py", line 2506, in execute_activate_changes
    warnings = get_config_domain(domain_request.name)().activate(domain_request.settings)
  File "/omd/sites/az_de_s1/lib/python3/cmk/gui/watolib/config_domains.py", line 97, in activate
    return {"restart": restart, "reload": reload}[active_config.wato_activation_method](
  File "/omd/sites/az_de_s1/lib/python3/cmk/gui/watolib/check_mk_automations.py", line 306, in restart
    _automation_serialized("restart", args=hosts_to_update),
  File "/omd/sites/az_de_s1/lib/python3/cmk/gui/watolib/check_mk_automations.py", line 58, in _automation_serialized
    cmdline, serialized_result = check_mk_local_automation_serialized(
  File "/omd/sites/az_de_s1/lib/python3/cmk/gui/watolib/automations.py", line 152, in check_mk_local_automation_serialized
    raise local_automation_failure(
cmk.gui.watolib.automations.MKAutomationException: Error running automation call restart (exit code 1), error:
Output of site status command:
agent-receiver: running
mkeventd:       running
liveproxyd:     running
mknotifyd:      running
rrdcached:      running
cmc:            running
apache:         running
dcd:            running
redis:          running
stunnel:        running
xinetd:         running
crontab:        running
Overall state:  running
This can have several issues. Most common what i had was a activation done by the DCD.
After 1 or. 2 minutes my manual activation was working without problem.
