Changes to "Network interfaces and switch ports" service monitoring rule not being saved
CMK version: 2.4.0p2 (also occurred on 2.4.0p1)
OS version: Docker
Hello! I am attempting to create a “Network interfaces and switch ports” service monitoring rule to ignore “operating speed” and “operating state” for certain ports.
However, when I attempt to create a rule with these options enabled and click Save, the values are not being saved. When I edit the new rule, those two options are not kept.
Here are some screenshots, however as a new user I only seem to be able to upload one image and two links.
Creating new rule:
Empty value column: https://imgur.com/a/u4bg9hU
Edit the rule, options not saved: https://imgur.com/a/9otYYIl
I am new to Checkmk so I am not sure how to collect any relevant logs. Please let me know what else you need from me to troubleshoot.
Thank you in advance for your time!
Interesting, seems to be a bug.
I could repro this on CRE 2.4.0p2 on Ubuntu, although other settings in the rule properly save, but operating speed and operating state do not.
Thanks for reporting. I have opened an internal ticket on this. Will keep you posted on the progress of the fix.
I got the same error, looking forward to the fix.
Thanks
same here on 2.4.0p2.cre
The problem has been fixed as part of this werk: Werk #18191: Fix saving of Network interfaces and switch ports rule
Good Morning @christian321,
2.4.0p5 has been released this week.
Can you confirm, that this fixes your issue?
Sunny Greetings and thank you
Hartmut
Hello Hartmut,
The issue is resolved for me in 2.4.0p5.
