HI,
I am looking at changing the Alert state in check_Mk for example if Missing Agent section is showing as WARN now I want to change it OK state how can we do it in check_MK version 1.4.0p37.
HI,
in Monitoring Configuration you will find a Service State translation. This should help.
Either that or configure the discovery service to not go WARN if a service has vanished.
hi
We are on 1.4.0p37 can you let me know the exact path for this configuration
thanks in advance
is in WATO -> Host & Service parameters -> Monitoring configuration -> Service State translation.
Thanks chris but unfortunately I don’t have any option for service state translation in monitoring conffiguration
Too bad. It was introduced in 1.5 with this werk:
https://checkmk.de/check_mk-werks.php?werk_id=5532
is there any way we can find it in 1.4.0p37
