Check_http through agent
Hello I want to check the webiste running on port 8080, that port is closed from the monitoring server. How do can I check it from the agent so I can bypass the firewall rule? I use the “Check HTTP service” under “Host & Service Parameters”
you could deploy the check_http-Plugin in the agent and configure it to run via mrpe.
Let me know if you need more information about this.
Karl
The ruleset “Check HTTP service” configures an active check that runs on the monitoring server and tries to reach the webserver over the network.
From where to download and install check_http plug in? I found https://www.nagios.org/downloads/nagios-plugins/ but it contains too many other plugins.
check_http is included in Checkmk. You can find it below your site’s directory in
~/lib/nagios/plugins/check_http
It works by doing those steps:
  1. scp /lib/nagios/plugins/check_http username@agent_server:/usr/lib/check_mk_agent/plugins
  2. vim /etc/check_mk/mrpe.cfg
  3. write: health-check /usr/lib/check_mk_agent/plugins/check_http -H localhost -p 8080
  4. test it: check_mk_agent | grep -A1 ‘^…mrpe’
  5. Go to WATO, hosts, services and enable the new service
  6. Apply the new changes and done
