**Error message:HTTP/1.1 503 Service Temporarily Unavailable
[cpu_tracking] Start with phase ‘busy’
Check_MK version 1.5.0p19
FETCHING DATA
[cpu_tracking] Push phase ‘agent’ (Stack: [‘busy’])
[piggyback] No persisted sections loaded
[cpu_tracking] Pop phase ‘agent’ (Stack: [‘busy’, ‘agent’])
[cpu_tracking] End
OK - execution time 0.0 sec | execution_time=0.002 user_time=0.010 system_time=0.000 children_user_time=0.000 children_system_time=0.000 cmk_time_agent=0.000
Hi there,
I have two web-based applications in an AWS VPC, both behind an application load balancer and both sharing an external IP address. There are target groups configured in AWS so if you come in via url1.aws.com it directs you to one application, and url2.aws.com directs you to the other. However, if you hit just the external IP address you’ll get the 503 error because no target group is configured for that.
My issue is that when trying to do standard HTTP URL check monitoring via CheckMK, it seems to me like it’s converting the URL to the IP address and so as far as it can tell the application is unavailable.
Am I correct in this assumption and, if so, am I missing something to force it to go to the actual URL/hostname?
Thanks for your response. Yes, yes it would Unfortunately that’s not possible in our current situation, but we are in the process of replacing a lot of our internal infrastructure with cloud-based stuff. However, we still need to use the version we’re on just now for monitoring of some of the AWS-based infrastructure, until we’ve got everything else set up (arse-about-face I’ll admit but that’s where we are).
So with that said, any advice/recommendations (outside of upgrading)?
Thanks for your reply. Will that not set it for any service that uses check_http? Does that therefore not mean I’ll need to create a new ruleset for each host/URL?
