Check Http with custom headers
Cloid Edition:
400 Bad Request
I added all my HTTP config in CheckMK, I added my custom headers in Post METHOD as, name: value.
But not working
you need to give more details.
What does your rule look like exactly?
What is your expected output?
What do you get instead?
screenshots help :slight_smile:
Hi, thanks!!
My custom header is: Ocp-Apim-Subscription-Key
and has a value: xxxxxxxx
HTTP WARNING: HTTP/1.1 404 Resource Not Found - 265 bytes in 0.105 second response time
Have you tried “Additional header lines” ?
From the command line, the option is -k
-k, --header=STRING
Any other tags to be sent in http header. Use multiple times for additional headers
I tried in Additional headers lines too, but maybe I don´t know how I need to type them there.
How can I set up it by the terminal?
–header=STRING?
I appreciate it!
