Check_httpv2 cert check on own CA webservices: error trying to connect: invalid peer certificate: UnknownIssuer
CMK version: 3.2.0 raw
OS version: Ubuntu Server 22.04
Since I switched my cert checks from check_http (now deprecated in 2.3.0) to check_httpv2 I get the following error message for Web-Services that are using our internal CA:
Example URL: https://greenbone.ms.wvk.lwl.org
OMD[cmk]:/opt/omd/sites/cmk/lib/nagios/plugins$ ./check_httpv2 -vvv --url https://greenbone.ms.wvk.lwl.org
2024-04-30T15:35:34.899472Z TRACE send_request: hyper::client::pool: checkout waiting for idle connection: ("https", greenbone.ms.wvk.lwl.org)
2024-04-30T15:35:34.899513Z DEBUG send_request: reqwest::connect: starting new connection: https://greenbone.ms.wvk.lwl.org/
2024-04-30T15:35:34.899526Z TRACE send_request: hyper::client::connect::http: Http::connect; scheme=Some("https"), host=Some("greenbone.ms.wvk.lwl.org"), port=None
2024-04-30T15:35:34.899604Z DEBUG hyper::client::connect::dns: resolving host="greenbone.ms.wvk.lwl.org"
2024-04-30T15:35:34.900535Z DEBUG send_request: hyper::client::connect::http: connecting to 172.25.64.80:443
2024-04-30T15:35:34.900807Z DEBUG send_request: hyper::client::connect::http: connected to 172.25.64.80:443
2024-04-30T15:35:34.900828Z DEBUG send_request: rustls::client::hs: No cached session for DnsName("greenbone.ms.wvk.lwl.org")
2024-04-30T15:35:34.900912Z DEBUG send_request: rustls::client::hs: Not resuming any session
2024-04-30T15:35:34.900935Z TRACE send_request: rustls::client::hs: Sending ClientHello Message {
    version: TLSv1_0,
    payload: Handshake {
        parsed: HandshakeMessagePayload {
            typ: ClientHello,
            payload: ClientHello(
                ClientHelloPayload {
                    client_version: TLSv1_2,
                    random: 013df31011c981a1196ba8d62590d60f3444d0eec6c9dad3baa7345537d8baa0,
                    session_id: 8ce29d1dc140961a7cb5e21e58b0a68c818d50a6b8350a33b94a34d03a2576e3,
                    cipher_suites: [
                        TLS13_AES_256_GCM_SHA384,
                        TLS13_AES_128_GCM_SHA256,
                        TLS13_CHACHA20_POLY1305_SHA256,
                        TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384,
                        TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256,
                        TLS_ECDHE_ECDSA_WITH_CHACHA20_POLY1305_SHA256,
                        TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384,
                        TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256,
                        TLS_ECDHE_RSA_WITH_CHACHA20_POLY1305_SHA256,
                        TLS_EMPTY_RENEGOTIATION_INFO_SCSV,
                    compression_methods: [
                        Null,
                    extensions: [
                        SupportedVersions(
                                TLSv1_3,
                                TLSv1_2,
                        ECPointFormats(
                                Uncompressed,
                        NamedGroups(
                                X25519,
                                secp256r1,
                                secp384r1,
                        SignatureAlgorithms(
                                ECDSA_NISTP384_SHA384,
                                ECDSA_NISTP256_SHA256,
                                ED25519,
                                RSA_PSS_SHA512,
                                RSA_PSS_SHA384,
                                RSA_PSS_SHA256,
                                RSA_PKCS1_SHA512,
                                RSA_PKCS1_SHA384,
                                RSA_PKCS1_SHA256,
                        ExtendedMasterSecretRequest,
                        CertificateStatusRequest(
                            OCSP(
                                OCSPCertificateStatusRequest {
                                    responder_ids: [],
                                    extensions: ,
                        ServerName(
                                ServerName {
                                    typ: HostName,
                                    payload: HostName(
                                        DnsName(
                                            "greenbone.ms.wvk.lwl.org",
                        SignedCertificateTimestampRequest,
                        KeyShare(
                                KeyShareEntry {
                                    group: X25519,
                                    payload: 3485ecad23a2c74b15ad0efc11509a9f03cd6c3289bce63f78d821e227f1c972,
                        PresharedKeyModes(
                                PSK_DHE_KE,
                        Protocols(
                                ProtocolName(
                                    6832,
                                ProtocolName(
                                    687474702f312e31,
                        SessionTicket(
                            Request,
        encoded: 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,
2024-04-30T15:35:34.905774Z TRACE send_request: rustls::client::hs: We got ServerHello ServerHelloPayload {
    legacy_version: TLSv1_2,
    random: e16d915e524176bffb90a9ac155355da40977bde0da7f132db59a3e297734b30,
    cipher_suite: TLS13_AES_256_GCM_SHA384,
    compression_method: Null,
    extensions: [
        SupportedVersions(
            TLSv1_3,
        KeyShare(
            KeyShareEntry {
                group: X25519,
                payload: eb76cf3822a0002b9468cb4751c3657a7176c79a9a1e1dc86791caf1500adf02,
2024-04-30T15:35:34.905802Z DEBUG send_request: rustls::client::hs: Using ciphersuite TLS13_AES_256_GCM_SHA384
2024-04-30T15:35:34.905816Z DEBUG send_request: rustls::client::tls13: Not resuming
2024-04-30T15:35:34.905820Z TRACE send_request: rustls::client::client_conn: EarlyData rejected
2024-04-30T15:35:34.905887Z TRACE send_request: rustls::conn: Dropping CCS
2024-04-30T15:35:34.905899Z DEBUG send_request: rustls::client::tls13: TLS1.3 encrypted extensions: [ServerNameAck, Protocols([ProtocolName(6832)])]
2024-04-30T15:35:34.905905Z DEBUG send_request: rustls::client::hs: ALPN protocol is Some(b"h2")
2024-04-30T15:35:34.905922Z TRACE send_request: rustls::client::tls13: Server cert is [Certificate(b"0\x82\x06\xff0\x82\x04\xe7\xa0\x03\x02\x01\x02\x02\x13\x15\0\0\x01\xeb\xe1\x06\r\xe2}>]\0\0\x02\0\0\x01\xeb0\r\x06\t*\x86H\x86\xf7\r\x01\x01\x0b\x05\00e1\x0b0\t\x06\x03U\x04\x06\x13\x02DE1\x0c0\n\x06\x03U\x04\x08\x13\x03NRW1\x110\x0f\x06\x03U\x04\x07\x13\x08Muenster1\x0c0\n\x06\x03U\x04\n\x13\x03KVW1\x0f0\r\x06\x03U\x04\x0b\x13\x06KVW-IT1\x160\x14\x06\x03U\x04\x03\x13\rKVW-MachineCA0\x1e\x17\r231117105846Z\x17\r251116105846Z0\x81\x801\x0b0\t\x06\x03U\x04\x06\x13\x02DE1\x1c0\x1a\x06\x03U\x04\x08\x13\x13Nordrhein-Westfalen1\x110\x0f\x06\x03U\x04\x07\x13\x08Muenster1\x0c0\n\x06\x03U\x04\n\x13\x03kvw1\x0f0\r\x06\x03U\x04\x0b\x13\x06kvw-IT1!0\x1f\x06\x03U\x04\x03\x13\x18greenbone.ms.wvk.lwl.org0\x82\x02\"0\r\x06\t*\x86H\x86\xf7\r\x01\x01\x01\x05\0\x03\x82\x02\x0f\00\x82\x02\n\x02\x82\x02\x01\0\x9e\xa3,+\x95\xe1&\xc4n\0h\xd99\x89\xe2t\xdcG\xac\xaa\xad5\xa7;\x82\xa1\x8c\xe5\x8cu\xfd\xe8\x01O\xd0/\x83\r\x08&F\xa8\x0eG{Q(\xb0\x159\x08\x80\xe2\x04n\xcc\xb7\xc2\xdfLX%\x85\x1b\xc3\xa7\x15\x83\x8c\x8c_\xc3\xd0f\r\x18\xbb\"\xba\xf6zT\xf0\x07\xccTe\xe5\xe8\x18\x7fF`G\x94UqR\x19Y<\xb6[\xccx\x04\xe2a\x983\xd1\xcaIG\xf5\xe0\x07\xe4\xca\xf7\xd8\xb4\x87\xcay@\xce\xb5\xd5\xf1e\xf5k$0\xc8\xa0P(\xa8\xe6\xb1\x88\x91U%\xca\x94\x8e@\xff\xf6\xfe_:,\x0bIO@\xe0\x86\x0f\x8e/,&s\xe8\x9a\xf9}\xcd\xb7=6\xbc\x93\xa4\xd8\x03.\x96M\xae\x8f\xd3\xea\x06$\xf6\xea\x8f\xd6sM\x8b\xb4|MnY\x01\x90\0\x0c\n&\x86@e>\xf3\xd7`\x84\x16\x19\xfa\x8f\xaf\xb4A\xa4\xb16\x01\xc5\xfc\xb8#5\x98\xf8\xb8\xda\xb6e\xc0s\x07x*\xe7@\x96\xed5<\xe9\xf2\xe8\xc5M\xb5\xec\xbc\xba/\xfd\xf5\x82\xa2\xba\xdd\xa2\x84\xccB\xe5%\xe5\x0fb\x12\xe9ijf\xf8\xe0tW[\xa6\x8bH\x94\xbf\x1c\x96\xba\xd5\xeb\xbeB0\x8a\x89\xa8\xb6\xf9\xact\xcd\xc71W\xee\xdfoYE7\xc8\x12\x07\xcc\xb2\xe1ep\xd6\xb0G\xf4\xaaJ\xb8\xcfZ\x99\x04\xcd\xe2+r\xa6\x06\xc2\x94\xebA\xfe\x97\xfbp9u\x9a0^\xdd\xc8\xd5Ub& \xad#80\xfe\xf8\xee\xe2\x1a\xfcEv\xe8\x1d\x13g\x8c\x1c_\xf2\x8eZ\xc3\xb0\xcf\xb5\\\xf82k\xd5?a\0\xd7V\xfa\xf1\xb8\xb7\xd8{85\xc9U\x90\xedu8x\xf5fDMH\xe9\x88)\xe0\xdc\xf8\xb0\x8d:\x91\xabc\x93Qd\x87\xeaw:\xba.$\x04\xde\xc4\xc3t\xed\xe8\xf0\x0c\x0f\xcd\xd8\xdb\x93\x0e\xa6T\xd3\xa0wv\xaa\x86\xcf\xbc\xe0bk\xd0\x07\x99.\xcbE\xd6\x1d\xe71_\xaf\xc1\x8a{\xb1\xfb6lq\xea\xae\xd9\x80u\x07V\xcc\xbe}\x97\xaeN\xd3\x02\xe9\x84\xcf3r.\xc8\x7f8\x8d\x02!\x02\x03\x01\0\x01\xa3\x82\x01\x8a0\x82\x01\x860\x0e\x06\x03U\x1d\x0f\x01\x01\xff\x04\x04\x03\x02\x05\xa00\x13\x06\x03U\x1d%\x04\x0c0\n\x06\x08+\x06\x01\x05\x05\x07\x03\x010.\x06\x03U\x1d\x11\x04'0%\x82\x18greenbone.ms.wvk.lwl.org\x82\tgreenbone0\x1d\x06\x03U\x1d\x0e\x04\x16\x04\x14\xea\xf6\xa9h\x9cgu\xd4\x8a\xa7l\x02E\xbcB\xc4\x1f\x8d\xe3.0\x1f\x06\x03U\x1d#\x04\x180\x16\x80\x14\xa3sGo\xa3Ak&\x17DD\xb5\x86\x1dvG\xab\xa5\xfdx0D\x06\x03U\x1d\x1f\x04=0;09\xa07\xa05\x863http://pki.kvw-muenster.de/pki/KVW-MachineCA(2).crl0O\x06\x08+\x06\x01\x05\x05\x07\x01\x01\x04C0A0?\x06\x08+\x06\x01\x05\x05\x070\x02\x863http://pki.kvw-muenster.de/pki/KVW-MachineCA(2).crt0;\x06\t+\x06\x01\x04\x01\x827\x15\x07\x04.0,\x06$+\x06\x01\x04\x01\x827\x15\x08\x83\x9f\xc9m\x82\xc8\xc2\x17\x86\xa9\x8d\x17\xc2\xc8\x03\xdc\xee\x16M\x81\x93\xaau\x82\x83\xafz\x02\x01d\x02\x01\x080\x1b\x06\t+\x06\x01\x04\x01\x827\x15\n\x04\x0e0\x0c0\n\x06\x08+\x06\x01\x05\x05\x07\x03\x010\r\x06\t*\x86H\x86\xf7\r\x01\x01\x0b\x05\0\x03\x82\x02\x01\01\x1a\xb46#\xd71\xb3\xaa\x99]B\x9f\xcd\xa0,\xec\xa5MF\xd6\xa3J\x0f\xf5\x86\xd9\x02vXJ\xe5\xd1\xc1\x07\x1b_\x81\x1c\xcbS\x89\xbe\xe5Z\x14k\xe2\xce1C\x9d$x\xaf\xfb\xf3X`\"~\xde`\xd9xv\xfe\xf3\x91O\xaed{4\xdb\xc9\xbf\xeef\\\x1b\xda\xd4\x03\x0e>\xbd\x83\xb0n\x7f(:\xc2\xf6^\xe8n\x04w]\xe3\x1d\x1a,\xe7\xc0\xe7\xc7\x95\xfd\xadnr\x94\x90\x0697\x8b\xbc\xde\xcb\x90\xd1x?\x90\x18x/\x18\xb1\xfc<\x1b\x90p\xc0\xac\xcf\xadm\x06Y\xf5@0\x06\xf9t\x0f[3\xb6\x9ct\x8c\xafM\xaff\x02\x8b\xb1@\xf7\xe4\xc7J\xb5^\x92sAQ\xc1J\xd8\xe5\xd4\x91\x05\x966\xf3!\x97\xa5\xe9\x15\x8d\x96f(\xcf\x80\x1cD\x02\x83\xe5*\x04L\xf2\x90/\xdc\x07\xc4\xc6\xca\xa2}\x02\xd0'\xe01\xb0\x91DJ\xd1\xe5\xba1D\xa7\xae\x928*\x8b{)\xf5Y\xda\x11S\x90\x83\xa9\x05\xc7\xd2\xdb\xc1Lpq\xbe\xa3[=\xa5\x7f\xb9}$Sb\x82\x02w:K\xf0\xbb\xc57\x8c\xf0\x16[\xf1g\xc6bQ\xfeQ;\0\xfc\x9c_\xed\xb7\x8dtKC0c2\xd78L\xae\xf7\x82\x17J\x88t\x04\x1ee\xd4\xb2/\xb2\x8eO\xb0\x9fS\xefu<\xb0\x1bP\xb4\x8b\xf0\xc4\xcb0\xff4z\xd5uN|\xc0\x9e\xe3\xe4~\x13p\xa8\x1f\x0c\xbc\x93\xb2\xb6\xccH\x0b$\xb0\xd4X8\xaa\x17|lA\xe4\xf2\x93mI`\x18\t\x02\xe0\xc2kA\xd6\xcf\xda(\xc2}Il\xf9\xf1\x99,\x92:Gy\xa8x\xf82\n\xe7\x98\xeb\x1au\x13\xc3+\xda\xe2\xfa\xa5`\xadd\xbb^\x17\xe9_\x1e\xdd\xfe\xd1e\x98Q\xd2\x9f\xa8o:2\xdeU{(\xf6\xc3R1\xc0\xe3}x\x04Cn;5v>\xbfB\x02\x94\xe7\x92mN\xb5\xd7\n36\xce\xcd\xcc\x14\xe9\0\xbc\xc6\xdb\x19a\xdc/\xc0\xcajw\xee?\xab\xe5\x02\xdc\xaf+A\x98Xw\x15\x12\xa7\xb3b\xa6\xc6Oh\xc2+\x8c\x12\x1b4*kt")]
2024-04-30T15:35:34.906050Z TRACE send_request: hyper::client::pool: checkout dropped for ("https", greenbone.ms.wvk.lwl.org)
error sending request for url (https://greenbone.ms.wvk.lwl.org/): error trying to connect: invalid peer certificate: UnknownIssuer (!!)
How can I fix this? So that I am not getting an error?
Have you also checked check_cert?
 ~/lib/nagios/plugins/check_cert --url greenbone.ms.wvk.lwl.org --port 443
OK - Certificate obtained in 51 ms, Verification: OK, Certificate expires in 54 day(s) (Jun 24 06:36:22 2024 +00:00)
response_time=51ms;60000;90000;;
Certificate chain verification OK
validity=54;30;0;;
Is it possible that the ca certificate is missing in the chain send by your webserver? Or better said no chain was send?
Thanks, that was the problem :sweat_smile:
The webserver does not need to send the CA root certificate, only the intermediates.
The client (in this case check_httpv2) needs to have the CA root certificate locally to verify from the end of the certificate chain.
Having a similar problem on a LAN scope with the same basic error message:
OMD[mysite]:~/lib/nagios/plugins$ ./check_httpv2 --url https://10.10.10.10:12345
error sending request for url (https://10.10.10.10:12345/): error trying to connect: invalid peer certificate: UnknownIssuer (!!)
OMD[mysite]:~/lib/nagios/plugins$ ./check_http --ssl -L --sni -p 12345 -I 10.10.10.10
<A HREF="https://10.10.10.10:12345/" target="_blank">HTTP OK: HTTP/1.1 200 OK - 4907 bytes in 0.050 second response time </A>|time=0.050296s;;;0.000000;10.000000 size=4907B;;;0;
What makes it difficult is that a) it’s some stupid auto-signed cert issued to localhost yet forces https over http, and b) I don’t have access to where I suspect the .crt to be in order to import it to checkmk and (hopefully) force-accept it.
Browsers say it’s invalid too, I’m not sure why it worked with check_http v1 to begin with but it did. :sweat_smile:
Simplest way (short of just leaving it on v1 until that feature gets kicked out, and then… concocting something, I guess) would be to just have something akin to curl -l / wget --no-check-certificate but the new plugin doesn’t feature that option. :face_with_diagonal_mouth:
:heavy_minus_sign: :heavy_minus_sign: :heavy_minus_sign:
:pencil2:: Well, I found the cert eventually and managed to import the right one, alas…
OMD[mysite]:~$ lib/nagios/plugins/check_httpv2 --url https://10.10.10.10:12345
error sending request for url (https://10.10.10.10:12345/): error trying to connect: invalid peer certificate: NotValidForName (!!)
Not sure how to fix that one, since the CN this thing is issued to is “localhost” :face_with_peeking_eye: and there doesn’t seem to be an ignore option.
:slight_smile:
Maybe you can put this strange certificate in the site trust store and try the check again ?
Setup >> General >> Global settings >> Trusted certificate authorities for SSL
Thanks for the suggestion -
I tried that already once I managed to locate and extract it, it’s what merely changed my error from “UnknownIssuer” to “NotValidForName” because of the awkward “localhost” CN (and no SAN) in it.
I`m running in the same Problem what was your solution ?
Not perfectly sure anymore, but I think in case of “not valid for name”, the problem was how the cert was issued to begin with, and the only solution was to use the legacy plugin (“Check HTTP service (deprecated)”). Still running some checks based on that one in such cases.
think also for the moment the only working solution … :frowning:
I’ve found that in theory, some cases getting “NotValidForName” might be fixable through Individual Settings → Connection Buildup → Additional Header Lines → Name: “Host” ; Value: “example.com”
This should function as an equivalent to setting a different virtual host in the old HTTP plugin.
In practice, that didn’t work for me though, I ended up with just a different error in the one check it was applicable to try that on (doesn’t look like the same one my old post was about, that must have resolved that fundamentally in the meantime). But in theory, it might in some cases unless I’m simply mistaken. :sweat_smile:
I hope a “Ignore certificate errors” option gets added to the new check. For some software I can’t even change the certificate even if I wanted to, but monitoring it via a simple HTTPS request would add a lot of functionality to our monitoring setup.
You don’t need to change it - add this certificate or it’s issuer certificate to your site cert store and it should work.
This is a workaround, not a solution. With this the certificate “manager” would need some changes. Right now I have to count to know which certificate to remove/replace, keeping up with these updates adds complexity, and all that even though neither me nor the developer of that software are interested in the validity of the certificates for this specific use case.
Why not add a simple check box and use what is already available within the used frameworks for the few cases this would make things some much easier?
Also, an option to change cipher suites would be great. I have an older TLS1.2 service not supporting GCM ciphers, so I can’t check it with V2. The 10 ciphers the V2 offers isn’t a bad selection, but it doesn’t contain all TLS 1.2 ciphers. I don’t know if this is a checkmk problem or underlying framework problem.
If I wanted to check for the correct certificate, I would use the “Check certificates” rule. And I’m using it for everything where this is important to monitor the certificate itself. But IMHO the HTTP check should just concern itself more with the data from the server, not how it got to it if I don’t need to check for that.
This seems to be the case for both Checks “Check certificates” and “Check HTTP web service” .
Both Checks have a the same problem of not beeing able to check a certificate without importing the certificate locally.
This would be a huge drawback compared to the deprecated http check and a pointless “improvement” to it.
It just adds additional expenses.
The “Check Certificate” Check results in a Warning with the Message “WARNING - Certificate obtained in 28 ms, Certificate chain verification failed: unable to get local issuer certificate WARN, Certificate expires in … day(s)”
It doesnt seem to make sense that a check was implemented that somehow gives you a less featurable option to check you certificates.
No, the “Check Certificates” works as it should. If you need to know when a certificate expires and general TLS connection is possible, this is what you want. With your external reachable servers you don’t even need to import a certificate, for internal services (or external ones signed internally) you would have a PKI anyways whose Root CA certificate you have to import once every 8 years or so.
It would make no sense to check a certificates expiry just to ignore if the chain is correct. Yes, it would still work in a browser, but TLS says you have to send every certificate in the chain except the one of the Root CA. And obviously your checkmk either doesn’t know about the Root CA or your server isn’t sending all required certificates.
If you don’t care for the certificates correctness, don’t check for it. If you want to test the reachability of your service, the HTTP one would be the right one. There you can say if you want to also check for certificate correctness or, as I would like it for a few selective services, ignore the TLS handshake and just check the response.
In our Case we monitor a customer system in which the customer is only interested in the certificate age and experation date.
You assumed that the customer wants to know the correctness of the chain which might be interesting but doesnt apply to this specific customer request.
Adding the Self-Signed certificate to the site’s cert store would fulfill the OpenSSL requirement to check a certificate’s validity against its CA.
I do want to caution you that before doing such action you check the certificate to NOT contain a/the flag CA: true.
As this would mean a/the certificate is able to sign other certificates, which if you were to import that one into your store every consecutively signed certificate is auto-trusted !
imho trusting such a certificate in your site cert-store could open up pandora’s box.
  • Glowsome
