CMK version: CMK Raw 2.2.0p21
OS version: Debian
Error message: Some mailboxes are not available {INBOX}
Using a password that starts with an exclamation mark like “!password” will result in a wrong escaping of the commandline call to the active mailboxes check. Due to that, the login fails.
./check_mailboxes --fetch-protocol=IMAP --fetch-server=hostname --fetch-tls --fetch-port=XXX --fetch-username=redacted@domain '--fetch-password=\!password' --warn-age-oldest=30 --crit-age-oldest=21600 --debug --mailbox INBOX -vvvv
DEBUG:check_mailboxes:use protocol for fetching: 'IMAP'
INFO:check_mailboxes:connect..
DEBUG:check_mailboxes:_connect_fetcher: 'IMAP' 'hostname' XXX True
49:22.33 imaplib version 2.58
49:22.33 new IMAP4 connection, tag=b'HEFA'
49:22.37 < b'* OK The Microsoft Exchange IMAP4 service is ready.'
49:22.37 > b'HEFA0 CAPABILITY'
49:22.37 < b'* CAPABILITY IMAP4 IMAP4rev1 AUTH=PLAIN AUTH=NTLM AUTH=GSSAPI SASL-IR UIDPLUS MOVE ID UNSELECT CHILDREN IDLE NAMESPACE LITERAL+'
49:22.37 < b'HEFA0 OK CAPABILITY completed.'
49:22.37 CAPABILITIES: ('IMAP4', 'IMAP4REV1', 'AUTH=PLAIN', 'AUTH=NTLM', 'AUTH=GSSAPI', 'SASL-IR', 'UIDPLUS', 'MOVE', 'ID', 'UNSELECT', 'CHILDREN', 'IDLE', 'NAMESPACE', 'LITERAL+')
49:22.37 > b'HEFA1 LOGIN redacted@domain "\\\\!password"'
49:22.41 < b'HEFA1 NO LOGIN failed.'
49:22.41 NO response: b'LOGIN failed.'
File "/omd/sites/site/lib/python3/cmk/utils/mailbox.py", line 336, in _connect_fetcher
_connect_imap()
File "/omd/sites/site/lib/python3/cmk/utils/mailbox.py", line 318, in _connect_imap
verified_result(connection.login(self._args.fetch_username, self._args.fetch_password))
File "/omd/sites/site/lib/python3.11/imaplib.py", line 612, in login
raise self.error(dat[-1])
imaplib.IMAP4.error: b'LOGIN failed.'
File "/opt/omd/versions/2.2.0p21.cre/lib/nagios/plugins/./check_mailboxes", line 169, in <module>
active_check_main(create_argument_parser(), check_mailboxes)
File "/omd/sites/site/lib/python3/cmk/utils/mailbox.py", line 944, in active_check_main
exitcode, status, perfdata = _active_check_main_core(argument_parser, check_fn, sys.argv[1:])
File "/omd/sites/site/lib/python3/cmk/utils/mailbox.py", line 895, in _active_check_main_core
return check_fn(args)
File "/opt/omd/versions/2.2.0p21.cre/lib/nagios/plugins/./check_mailboxes", line 88, in check_mailboxes
mailbox.connect()
File "/omd/sites/site/lib/python3/cmk/utils/mailbox.py", line 297, in connect
self._connect_fetcher()
File "/omd/sites/site/lib/python3/cmk/utils/mailbox.py", line 344, in _connect_fetcher
raise ConnectError(
cmk.utils.mailbox.ConnectError: Failed to connect to fetching server exc01: b'LOGIN failed.'
