elkhedewy
(Amr Elkhedewy)
November 11, 2025, 2:15pm
1
I’ve centos 9 stream installed on my vm and i installed check mk agent rpm successfully but i didn’t find xinetd available on EPEL.
So what will happen if i used the agent without xinetd?
or what should i do instead to start monitor the vm in normal way?
r.sander
(Robert Sander)
November 11, 2025, 2:29pm
2
Today the agent is started via systemd socket unit or a systemd service unit for the agent controller.
elkhedewy
(Amr Elkhedewy)
November 11, 2025, 3:02pm
3
i’ve check mk version 1.6.0, So now i don’t need to use xinetd on centos 9? is that what you mean?
or should i install another packaged instead?
CFriedrich
(Christian Friedrich)
November 11, 2025, 4:32pm
4
Why do you use cmk 1.6?
It’s quite old and out of support…
Regards, Christian
elkhedewy
(Amr Elkhedewy)
November 12, 2025, 2:20pm
5
Should i upgrade to the latest version at one time. or what is your recommendations?
Sara
November 17, 2025, 10:40am
6
As I recall, updates are done version by version: to the latest patch of the major version, then the latest patch of the next version and so on, but as 1.6 is a very old version, it might make sense to start anew.
If you decide not to do that, starting the migration from 1.6 would be described here: Updates and Upgrades
