Check_MK cannot connect after installation. I have installed the RAW version 1.4.16, configured IP address with subnet 22 & the right gateway. But ping results dont respond giving request timed out. Also Web version http://IP Address dont work expectedly. What am I missing here.
Hi rprengel,
Firewall is active & thats why, its understood that it wont work with HTTP from user network. But even when accessing from Datacenter network which is open, it still does not work.
Hi Andreas,
How Do I check Apache in the VM?
I installed the RAW/Free version whatever is available here:
If some other free version available for setup, I’ll be happy to install it. Problem is, based on the OVA file deployment instruction I went ahead & installed the VM. Configured IP as instructed. After that, I cannot get into the system for any configuration.
The next instruction is to try & access the site from http://machine IP Address which is not working.
Hi Andreas,
We have installed version# 1.4.16
It was provided from here: Download Checkmk for free | Checkmk
If there is an advanced version to work with, I would happily install it.
But, even this version installed just fine. I configured iP address & enabled Web configuration & SSH. LAN status shows UP & green. But I cannot ping or reach the IP address. Which is why I cannot control the site from the web.
Anything I am doing wrong here?
This is the appliance version. How does your network config looks like for this deployed appliance. If you cannot reach the machine then the possibility is very high that something in your virtual environment is not correctly configured. I deployed 4 virtual appliances last week and had no problem on any one of these.
some general hints
1)
subnetmask and gateway ok
2)
virtual netwerkinterface and virtual switch ok (Vmware ESX)
3)
any endpoint or other security-solutions active
4)
other virtual systems on same host are working
Subnet masks & gateways are all good.
Network interface is just like other interfaces.
Other virtual system are working using the same virtual switch configuration. Is there any work around?
It would help to see the configuration. As i said last Friday i deployed 4 virtual appliances inside VMware and had not a single problem. What virtualization platform do you use?
