I use check_mk RAW 1.6.0p12 and there seems to be something broken with the check_mk Ceph integration.
This is my RAW output:
$ check_mk_agent
... snip ...
<<<ceph_df>>>
RAW STORAGE:
CLASS SIZE AVAIL USED RAW USED %RAW USED
ssd 912 TiB 323 TiB 588 TiB 589 TiB 64.61
TOTAL 912 TiB 323 TiB 588 TiB 589 TiB 64.61
POOLS:
POOL ID STORED OBJECTS USED %USED MAX AVAIL QUOTA OBJECTS QUOTA BYTES DIRTY USED COMPR UNDER COMPR
isos 1 575 GiB 147.98k 1.7 TiB 0.63 89 TiB N/A N/A 147.98k 0 B 0 B
rbd 3 204 TiB 60.07M 586 TiB 68.68 89 TiB N/A N/A 59.86M 0 B 0 B
test 4 7.9 MiB 2.01k 68 MiB 0 89 TiB N/A N/A 2.01k 0 B 0 B
internal 5 19 B 2 36 KiB 0 89 TiB N/A N/A 2 0 B 0 B
but in our monitoring it tells me that the max available size is:
Service description | Ceph Pool rbd
Output of check plugin | WARN - 86.81% used (586 of 675 TB), (warn/crit at 80.0%/90.0%), trend: -1.32 TB / 24 hours
Any Ideas?
