beim Systemstart wird der omd/checkMK per script gestaret - welches folgende Ausgaben hat: (ist das normal so?)
OS: SLE15-1
CMK: 1.6.0p6
Failed to restart ntp.service: Unit ntp.service not found. (ist jetzt chrony, muss ich noch rausnehmen ;-))
Restarting OMD SITENAME
Removing Crontab...OK
Stopping xinetd...OK
Stopping Nagios Service Check Acceptor...OK
Stopping apache...killing 1937.......OK
Stopping nagios....OK
Stopping npcd...OK
Stopping rrdcached...waiting for termination...OK
Stopping mkeventd...killing 1845....OK
Starting mkeventd...OK
Starting rrdcached...OK
Starting npcd...OK
Starting nagios...OK
Starting apache...OK
Starting Nagios Service Check Acceptor...OK
Starting xinetd...OK
Initializing Crontab...OK
File "/usr/bin/omd", line 65, in <module>
omdlib.main.main()
File "/omd/versions/1.6.0p6.cre/lib/python/omdlib/main.py", line 4748, in main
command_function(site, args, command_options)
File "/omd/versions/1.6.0p6.cre/lib/python/omdlib/main.py", line 4450, in <lambda>
lambda site, args, opts: main_init_action(site, "restart", args, opts), [
File "/omd/versions/1.6.0p6.cre/lib/python/omdlib/main.py", line 3435, in main_init_action
exit_status = init_action(site, command, args, options)
File "/omd/versions/1.6.0p6.cre/lib/python/omdlib/main.py", line 2334, in init_action
return call_init_scripts(site, command, daemon)
File "/omd/versions/1.6.0p6.cre/lib/python2.7/contextlib.py", line 24, in __exit__
self.gen.next()
File "/omd/versions/1.6.0p6.cre/lib/python/omdlib/main.py", line 193, in chdir
os.chdir(prev_cwd)
OSError: [Errno 13] Permission denied: '/root'
Mit freundlichen Grüßen
Jens Franik
