AWS recently changed the way we calculate and display account limits for your EC2 instances, allowing for greater flexibility in using
your EC2 instances and allowing for faster and more convenient switches within instance types and families. In the past we would have displayed your limits on a per instance type basis (m5.large, m5.xlarge, m5.2xlarge etc) whereas after this switch, we are
displaying limits in a smaller number of overarching buckets, which are based upon the number of vCPUs used by each instance. Since we’ve summarized all of the EC2 limits into this smaller number of buckets, this will allow you to switch between instance types
without the requirement of having each limit increased individually, saving you time and effort. I’ve now increased your “nu.General” bucket limit from 640 to 960 vCPUs which corresponds to the 20 c5.4xlarge you requested. If you’d like to calculate your vCPU
limit in future, please visit the following link: https://console.aws.amazon.com/ec2/v2/home?region=us-east-1#LimitsCalculator: -
and choose the relevant region in the top right corner of the console. You can then also conveniently request a vCPU based limit increase via the support centre. If you’d like further information, please see this link for additional details: https://aws.amazon.com/ec2/faqs/#EC2_On-Demand_Instance_limits I
hope this helps!
Wie kann ich denn jetzt den „roten“ Alarm wegbekommen oder muss dafür der Check Umgebaut werden sodass er sauber funktioniert ?
allowing for greater flexibility in using your EC2 instances and allowing for faster and more convenient switches within instance types and families. In the past we would have displayed your limits on a per instance type basis (m5.large, m5.xlarge, m5.2xlarge
etc) whereas after this switch, we are displaying limits in a smaller number of overarching buckets, which are based upon the number of vCPUs used by each instance. Since we’ve summarized all of the EC2 limits into this smaller number of buckets, this will
allow you to switch between instance types without the requirement of having each limit increased individually, saving you time and effort. I’ve now increased your “nu.General” bucket limit from 640 to 960 vCPUs which corresponds to the 20 c5.4xlarge you requested.
If you’d like to calculate your vCPU limit in future, please visit the following link: https://console.aws.amazon.com/ec2/v2/home?region=us-east-1#LimitsCalculator: -
hope this helps!
Hallo Marcel,
die Limits bei AWS wurden zwischenzeitlich geändert. Sie werden nun
nicht mehr pro Instancetyp sondern über die Gesamtanzahl der genutzten
Kerne bestimmt. Das wurde von AWS vor einigen Wochen bekannt gegeben.
Es gab da noch Übergangsfristen, die zwischenzeitlich abgelaufen sein
könnten.
Ob und in welcher Form das Auswirkungen auf die von Checkmk verwendete
API hat, kann ich Dir leider nicht sagen.
Ich finde die derzeitige Implementierung für die Regeln bei Limits
sehr unflexibel und hatte daher vor Wochen ein Feedbackticket
eröffnet, damit man die Limits über reguläre Ausdrücke definieren
kann.
Gruß
Thorsten
Am Di., 19. Nov. 2019 um 17:09 Uhr schrieb Werner, Marcel <Marcel.Werner@prosiebensat1.com>:
Hallo ,
Ich wollte gerade mal beginnen AWS zu überwachen da bin ich auf dieses Limit Thema gestossen.
Ich wollte nur die c5.4xlarge limits anpassen. Scheinbar hat AWS da was geändert.
AWS recently changed the way we calculate and display account limits for your EC2 instances, allowing for greater flexibility in using your EC2 instances and allowing for faster and more convenient switches within instance types and families. In the past we would have displayed your limits on a per instance type basis (m5.large, m5.xlarge, m5.2xlarge etc) whereas after this switch, we are displaying limits in a smaller number of overarching buckets, which are based upon the number of vCPUs used by each instance. Since we've summarized all of the EC2 limits into this smaller number of buckets, this will allow you to switch between instance types without the requirement of having each limit increased individually, saving you time and effort. I've now increased your "nu.General" bucket limit from 640 to 960 vCPUs which corresponds to the 20 c5.4xlarge you requested. If you'd like to calculate your vCPU limit in future, please visit the following link: https://console.aws.amazon.com/ec2/v2/home?region=us-east-1#LimitsCalculator: - and choose the relevant region in the top right corner of the console. You can then also conveniently request a vCPU based limit increase via the support centre. If you'd like further information, please see this link for additional details: Amazon EC2 FAQs – AWS I hope this helps!
