wir haben hier einen ceph-cluster mit 4 Nodes erstellt und möchten gerne die genutzten OSDs (SSDs) mit in den SMART Monitoring aufnehmen. Wenn ich smartctl direkt nutze, erhalte ich auch sofort Werte:
smartctl -A /dev/sda
smartctl 6.5 2016-01-24 r4214 [x86_64-linux-4.4.0-116-generic] (local build)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF READ SMART DATA SECTION ===
SMART Attributes Data Structure revision number: 1
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0
9 Power_On_Hours 0x0032 099 099 000 Old_age Always - 810
12 Power_Cycle_Count 0x0032 099 099 000 Old_age Always - 16
177 Wear_Leveling_Count 0x0013 100 099 005 Pre-fail Always - 0
179 Used_Rsvd_Blk_Cnt_Tot 0x0013 100 100 010 Pre-fail Always - 0
180 Unused_Rsvd_Blk_Cnt_Tot 0x0013 100 100 010 Pre-fail Always - 10992
181 Program_Fail_Cnt_Total 0x0032 100 100 010 Old_age Always - 0
182 Erase_Fail_Count_Total 0x0032 100 100 010 Old_age Always - 0
183 Runtime_Bad_Block 0x0013 100 100 010 Pre-fail Always - 0
184 End-to-End_Error 0x0033 100 100 097 Pre-fail Always - 0
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0
190 Airflow_Temperature_Cel 0x0032 072 061 000 Old_age Always - 28
194 Temperature_Celsius 0x0022 072 061 000 Old_age Always - 28 (Min/Max 26/39)
195 Hardware_ECC_Recovered 0x001a 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 100 100 000 Old_age Always - 0
199 UDMA_CRC_Error_Count 0x003e 100 100 000 Old_age Always - 0
202 Unknown_SSD_Attribute 0x0033 100 100 010 Pre-fail Always - 0
235 Unknown_Attribute 0x0012 099 099 000 Old_age Always - 13
241 Total_LBAs_Written 0x0032 099 099 000 Old_age Always - 2178046378
242 Total_LBAs_Read 0x0032 099 099 000 Old_age Always - 1444497527
243 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 0
244 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 0
245 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 65535
246 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 65535
247 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 65535
251 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 2955429888
Das smartplugin bleibt leider leer:
/usr/lib/check_mk_agent/plugins/smart
<<<smart>>>
Die Mountpoints sind wie folgt... z.B.:
/dev/sda1 on /var/lib/ceph/osd/ceph-12
Die Mountpoints werden auch von check_mk erkannt und zeigen die aktuelle Diskspaceusage an.
Hat jemand das gleiche Problem für das smart-Monitoring?
Beste Grüße
Jan
