I would like to know if there is a way to remove the information for the logwatch, i know there is a way to disable the services, but if i disable the logs checks, the check is still working, and this can be dangerous because the errors show personal information for the users.
I would like to know if there is a way to remove this function completely for the monitoring, and my records (Logs).
if you don’t want to use logwatch just remove the plugin from the monitored hosts. For windows there is a fine tune rule in the bakery to disable logwatch at all. By default Windows will bring you the default logs.
I understand that the logwatch is part of the CMK Agent, i dont use a plugin for this, my version is the RAW but i dont know if there is some configuration to eliminate this checks and the information
It has nothing to do with logwatch. These are Windows Event log checks. This is a misunderstanding.
You have to finetune the windows event log like this:
if you don’t want to see logs of Windows hosts in CMK, then you can use the rule Disabled sections in the agent bakery. When using the RAW edition, then disable the section in the agent yml file:
