[Check_mk (english)] alert if interfaice traffice is lower
Spam detection software, running on the system "mathias-kettner.de", has
identified this incoming email as possible spam. The original message
has been attached to this so you can view it (if it isn't spam) or label
similar future email. If you have any questions, see
postmaster@mathias-kettner.de for details.
Content preview: Hi All, can check_mk send alert while interface traffice is
   lower than specific values? like waring at lower than 10KB/s. I can only
  find a rule for alert while traffic is higher than xx. ( Network interfaces
   and switch ports -> Warning if above bits / bytes per second) [...]
Content analysis details: (5.5 points, 5.0 required)
pts rule name description
2.7 RCVD_IN_PSBL RBL: Received via a relay in PSBL
                            [220.181.15.112 listed in psbl.surriel.com]
0.0 FREEMAIL_FROM Sender email is commonly abused enduser mail provider
                            (k19840[at]126.com)
-0.0 T_RP_MATCHES_RCVD Envelope sender domain matches handover relay
                            domain
-0.0 SPF_PASS SPF: sender matches SPF record
0.2 FREEMAIL_ENVFROM_END_DIGIT Envelope-from freemail username ends in
                            digit (k19840[at]126.com)
0.0 HTML_MESSAGE BODY: HTML included in message
0.8 BAYES_50 BODY: Bayes spam probability is 40 to 60%
                            [score: 0.4884]
0.0 HTML_FONT_LOW_CONTRAST BODY: HTML font color similar or identical to
                            background
1.7 MIME_BASE64_TEXT RAW: Message text disguised using base64 encoding
0.0 T_DKIM_INVALID DKIM-Signature header exists but is not valid
The original message was not completely plain text, and may be unsafe to
open with some email clients; in particular, it may contain a virus,
or confirm that your address can receive spam. If you wish to view
it, it may be safer to save it to a file and open it with an editor.
