[Check_mk (english)] All active checks returning code 127
Hi list,
We’re currently seeing a strange issue with CMK version 1.2.3i1 which we have been running with no issues since it was released. When we inventory a new check and restart check_mk all active checks immediately start returning the 127 return code out of bounds error. If we remove that check, or any other check the issue rights itself. This makes me think that there is something mangling the automatically generate config file. Has anyone run in to this issue before?
Regards
**Dan Bason **
Infrastructure Engineer – Telogis
www.telogis.com www.telogis.co.nz
+1 201 477-1448 (USA) +64 3 281-8065 (NZ)
One Platform for Location Intelligence
This e-mail,
and any attachments, is intended only for use by the addressee(s) named herein
and may contain legally privileged and/or confidential information. It is
the property of Telogis. If you are not the intended recipient of this
e-mail, you are hereby notified that any dissemination, distribution or copying
of this e-mail, any attachments thereto, and use of the information contained,
is strictly prohibited. If you have received this e-mail in error, please
notify the sender and permanently delete the original and any copy thereof.
What kind of check, mrpe? If so, check the file permissions. Make sure the plugin files are owned by Nagios and can be executed.
On Mar 26, 2014, at 20:51, Daniel Bason daniel.bason@telogis.com wrote:
Hi list,
Regards
**Dan Bason **
This e-mail,
checkmk-en mailing list
All of the active checks return 127 (Events, inventory check, regular check_mk check and any other extra checks we have configured inside of main.mk).
It doesn’t seem to matter which passive check is added. I have seen this with mrpe, an additional logwatch check, and additional interfaces on a SNMP switch.
This e-mail,
On Thu, Mar 27, 2014 at 2:58 PM, Paul Monitoring paulmonitoring@gmail.com wrote:
Hi list,
Regards
**Dan Bason **
This e-mail,
**Dan Bason **
