[Check_mk (english)] APC Symmetra broken: check_mk-apc_symmetra.php
The location of the file not working on my system:
/opt/omd/versions/1.4.0p19.cre/share/check_mk/pnp-templates/check_mk-apc_symmetra.php
Obviously I am running check_mk version 1.4.0p19, but I found where somebody mentioned that this has been broken since 1.4.0p5
Is everybody just ignoring these APC metrics now or is there another solution for these metrics?
Thanks for any information you can give,
Ron
Hi Ron,
Quick and dirty fix is to copy the default PNP template to your /local/share/check_mk/pnp-templates and rename the default to the full name of the APC template.
It is then not the nicest graph but it should work.
Best regards
Andreas
ยทยทยท
Ron Skantz Ron.Skantz@barnhardt.net schrieb am Fr., 13. Juli 2018, 16:38: > The location of the file not working on my system:
Ron
PRIVILEGED AND CONFIDENTIAL: This electronic message and any attachments are confidential property of the sender. The information is intended only for the use of the person to whom it was addressed. Any other interception, copying, accessing, or disclosure of this message is prohibited. The sender takes no responsibility for any unauthorized reliance on this message. If you have received this message in error, please immediately notify the sender and purge the message you received. Do not forward this message without permission.
checkmk-en mailing list
