[Check_mk (english)] ASCII plugin error after upgrade to 1.6.0
  we just upgraded to 1.6.0 series from 1.5.0.
  We get this error with one of the plugins:
Loading "/omd/sites/master/local/share/check_mk/web/plugins/wato/cisco_asa_temp.py" failed: 'ascii' codec can't decode byte 0xc2 in position 0: ordinal not in range(128)
  The plugin in question is this:
https://checkmk.com/check_mk-exchange-file.php?&file=cisco_asa_temp-20160702.v0.2a.mkp
  Yes, the problem is this bit of code:
            Integer(title = _("warning at"), unit = _("° celsius"), default_value = 60 ),
            Integer(title = _("critical at"), unit = _("° celsius"), default_value = 70 ),
(The degree mark).
  Why is this character suddenly forbidden? What needs to be changed?
- Antti
Hi Antti,
the fix is easy.
This string must be coded as Unicode.
Change the line to
        Integer(title = _("warning at"), unit = _(u"° celsius"), default_value = 60 ),
        Integer(title = _("critical at"), unit = _(u"° celsius"), default_value = 70 ),
This should solve the problem.
With the actual version this is also solved - https://thl-cmk.hopto.org/gitlab/checkmk/cisco/asa/cisco_asa_temp
Best regards
Andreas
Am Do., 12. Dez. 2019 um 08:32 Uhr schrieb Antti Mäkelä antti.makela@advania.com:
Loading “/omd/sites/master/local/share/check_mk/web/plugins/wato/cisco_asa_temp.py” failed: ‘ascii’ codec can’t decode byte 0xc2 in position 0: ordinal not in range(128)
(The degree mark).
  • Antti
checkmk-en mailing list
https://lists.mathias-kettner.de/cgi-bin/mailman/listinfo/checkmk-en
The mailing list will be shut down by 31.12.2019. Sign up at the Checkmk Community forum: https://forum.checkmk.com.
Ah, right.
I guess it would be nice if these ex-plugins that have been included in the main tree would let you know that there's actually a newer implementation as part of the distribution now. Will remove the plugin.
- Antti
-----Original Message-----
Sent: torstai 12. joulukuuta 2019 23.27
To: Antti Mäkelä <antti.makela@advania.com>
Subject: Re: [Check_mk (english)] ASCII plugin error after upgrade to 1.6.0
Hi Antti,
the fix is easy.
Change the line to
Best regards
Andreas
Am Do., 12. Dez. 2019 um 08:32 Uhr schrieb Antti Mäkelä <antti.makela@advania.com <mailto:antti.makela@advania.com> >:
  (The degree mark).
   - Antti
  checkmk-en@lists.mathias-kettner.de <mailto:checkmk-en@lists.mathias-kettner.de>
Oh wait - it's not in the distribution actually, I didn't pay attention to the link. Was there some new place that points to this git tree? I always thought that check_mk exchange would be the go-to place for plugins...why is the version there outdated?
- Antti
From: checkmk-en <checkmk-en-bounces@lists.mathias-kettner.de> On Behalf Of Antti Mäkelä
Sent: perjantai 13. joulukuuta 2019 9.41
To: Andreas Döhler <andreas.doehler@gmail.com>
Ah, right.
- Antti
Hi Antti,
the fix is easy.
Change the line to
Best regards
Andreas
  (The degree mark).
   - Antti
Hi Antti,
This plugin is not included inside the main checkmk it is external also in the actual version. The Git repo is from my colleague at work :slight_smile:
Best regards
Andreas
Antti Mäkelä antti.makela@advania.com schrieb am Fr., 13. Dez. 2019, 08:40:
Ah, right.
I guess it would be nice if these ex-plugins that have been included in the main tree would let you know that there’s actually a newer implementation as part of the distribution now. Will remove the plugin.
  • Antti
To: Antti Mäkelä antti.makela@advania.com
Hi Antti,
the fix is easy.
Change the line to
Best regards
Andreas
Am Do., 12. Dez. 2019 um 08:32 Uhr schrieb Antti Mäkelä <antti.makela@advania.com mailto:antti.makela@advania.com >:
    [https://checkmk.com/check_mk-exchange-file.php?&file=cisco_asa_temp-20160702.v0.2a.mkp](https://checkmk.com/check_mk-exchange-file.php?&file=cisco_asa_temp-20160702.v0.2a.mkp)
    (The degree mark).
     - Antti
    [https://lists.mathias-kettner.de/cgi-bin/mailman/listinfo/checkmk-en](https://lists.mathias-kettner.de/cgi-bin/mailman/listinfo/checkmk-en)
    The mailing list will be shut down by 31.12.2019. Sign up at the Checkmk Community forum: [https://forum.checkmk.com](https://forum.checkmk.com).
