Hi Moritz,
thx! No - debug output doesn't help because some minutes after the unknown state
the debug output looks fine, the only thing I can see is quite after the Agentinfo
WARNING: not found: storage_percent (average)
WARNING: no timeseries found for metric u'P2SConnectionCount'
(but not related to a resource group). I guess the plugin tries to get these
values from the Agent directly (not related to a RSG)
Regards
Guenther
Gesendet: Donnerstag, 14. November 2019 um 09:00 Uhr
Von: "Moritz Kiemer" <moritz.kiemer@tribe29.com>
An: "guenther rasch" <guenther.rasch@gmx.at>
Betreff: Re: [Check_mk (english)] Azure checks - missing agent sections
Hi Guenther,
From the output of the "cmk -D <HOST>" command (replace your host name) you can see the actual commandline call for the agent_azure (around line 9 of the output, I think). Try adding the options "--debug" (to have exceptions raised) and "--sequential" (to turn off multi threading), and see if the output is helpful.
Regards,
Moritz
----- Ursprüngliche Mail -----
Von: "guenther rasch" <guenther.rasch@gmx.at>
An: "checkmk-en@lists.mathias-kettner.de" <checkmk-en@lists.mathias-kettner.de>
Gesendet: Donnerstag, 14. November 2019 07:38:58
Betreff: [Check_mk (english)] Azure checks - missing agent sections
we are monitoring Azure cloud services with check_mk 1.6.0p5. It's running good, the AzureService host
is configured to store data / map data to resource group hosts.
I've configured them all, it's working fine, but from time to time, I'm getting a warning for
different resource groups:
Successfully processed from source AzureService, Missing agent sections: azure_virtualmachines
The sections are not only azure_virtualmachines - they differ from time to time.
After a few minutes the message went away and all is "OK" again. The API-read limit is
not reached (10k left...).
Any ideas what's going wrong?
Regards
Guenther
checkmk-en mailing list
https://lists.mathias-kettner.de/cgi-bin/mailman/listinfo/checkmk-en
Moritz Kiemer
Join us at the Checkmk Conference #6 from April 27th-29th, 2020.
tribe29 — the checkmk company
moritz.kiemer@tribe29.com | Phone: +49 89 9982 097 00
