What do you use as a backup strategy for your site?
I’ve used three various ones with mixed results:
rsync’ing the wato snapshots off to another location --> This is my preferred because I’ve restored successfully this way
using ‘cmk --backup’ as the site user --> This is my least preferred due to inconsistent results. For example, running this command on 2.8p9 leads to a tiny .tgz with an empty main.mk and other empty dirs
using 'omd backup '. --> This seems to be mentioned by people in this forum, but the problem is it’s very slow due to all the .RRD files it has to copy over, many small files.
What do you use?
Matt
Hi Mathieu,
if I want a consistent backup what I can also easily restore “omd backup” is the first choice.
The speed depends on the capabilities of your disc system. A big site with SSD discs take 10-15 Minutes. As the actual versions don’t need to stop the site for an “omd backup” it is not so important how long it takes.
br
Andreas
Mathieu Levi mlevi+cmk@collective.com schrieb am Do., 12. Okt. 2017 um 19:21 Uhr:
- rsync’ing the wato snapshots off to another location → This is my preferred because I’ve restored successfully this way
- using ‘cmk --backup’ as the site user → This is my least preferred due to inconsistent results. For example, running this command on 2.8p9 leads to a tiny .tgz with an empty main.mk and other empty dirs
- using ‘omd backup ’. → This seems to be mentioned by people in this forum, but the problem is it’s very slow due to all the .RRD files it has to copy over, many small files.
What do you use?
Matt
checkmk-en mailing list
Thanks, Andreas. I have it running as a nightly job along with snapshots copied off the host as an extra measure. I see it runs an rsync under the hood (not quite as fast as a cp), and even with the --no-rrds option it takes quite a while on my site which is about 80 gigs large. RAID 10 config of 10K disks - not quite SSD, of course.
Matt
On Thu, Oct 12, 2017 at 4:50 PM, Andreas Döhler andreas.doehler@gmail.com wrote:
Hi Mathieu,
br
Andreas
What do you use?
Matt
80 Gig without RRD files? That would be way to large
One thing i do from time to time is search and remove obsolete/old RRD files.
My big single instances are not bigger then 20GB with RRD files. In one distributed system there some of these instances then but no single instances larger then 20-25GB.
br
Andreas
Hi Mathieu,
br
Andreas
What do you use?
Matt
