Greetings,
What is the best approach to modify the threshold of an inventoried
check? I’m using Multisite/WATO, OMDistro. (1.2.6p12) This is my
first time trying this. More specifically, I’m talking about the APC
Symmetra check, which was an automatically added inventory
check. I simply want to modify the voltage threshold from 225v to
115 for U.S. I’ve seen that there are a few ways to do this, but
I’m wondering the best? Also, can this be done IN WATO or only
through an .mk file.
Thanks!
Matt
-- Matthew Nickerson
Network Engineer
Computing Facilities, SCS
Carnegie Mellon University
(412) 268-7273
Hi Matthew,
you’re using WATO so that’s the best way doing this - by far! Easy to configure rules, always the right syntax…
Your specific question regarding APC… WATO → Host & service parameters → Parameters for discovered services → APC Symmetra Checks.
Don’t forget to rediscover affected hosts (“tabula rasa” in WATO discovery) because changed rules often apply only to newly discovered services. And - for sure - apply changes
HTH,
Marcel
Matthew Nickerson mnickers@cs.cmu.edu schrieb am Mi., 28. Okt. 2015 um 19:31 Uhr:
Greetings,
Thanks!
Matt
Network Engineer
(412) 268-7273
checkmk-en mailing list
Thanks, you are right. I did get it to work in WATO, but I must say
it is taking me a long time to see how all the components (host
groups, service groups, rules, grouping, host-tags, etc., etc.) all
fit together! It was/is a little frustrating. I kept going back to
config files for the changes I needed, until today… Thanks
again.
On 10/28/2015 3:13 PM, Marcel Schulte
wrote:
Hi Matthew,
you're using WATO so that's the best way doing this - by
Your specific question regarding APC... WATO -> Host
Don't forget to rediscover affected hosts ("tabula rasa" in
HTH,
Marcel
Matthew Nickerson <mnickers@cs.cmu.edu >
Greetings,
inventoried check? I’m using Multisite/WATO, OMDistro.
(1.2.6p12) This is my first time trying this. More
specifically, I’m talking about the APC Symmetra check, which was an
automatically added inventory check. I simply want to
modify the voltage threshold from 225v to 115 for U.S. I’ve
seen that there are a few ways to do this, but I’m wondering
the best? Also, can this be done IN WATO or only through an
.mk file.
Thanks!
Matt
Network Engineer
(412) 268-7273
Network Engineer
(412) 268-7273
