We have about 15-20 small offices in our WAN, and each office has a server (win or linux), a cisco router, etc. What I would like to do is monitor the link bandwidth (MPLS). Is this possible within check_mk? I have never had good luck getting “bandwidth” monitoring to work between offices using Nagios.
The Oppenheimer Group ---- CONFIDENTIAL
This message is for the designated recipient only and may contain privileged, proprietary, or otherwise private information. If you have received it in error, please notify the sender immediately and delete the original. Any other use of the email by you is prohibited.
We have a similar setup and check_mk (using snmp) on the cisco routers this is providing great details and graphs
cheers
Alex
cheers
Alex
This by default will watch all the interfaces on the routers and provided graphs on the bandwidth on each interface
behind all our cisco routers we have a some linux firewall’s with 11 virtual interfaces which check_mk also picks up by default and monitors the network bandwidth.
Each of the virtual interfaces are for each of the connections to each of the remote offices so it is very easy to see which office are using the bandwidth.
At each remote site we also have nagios/check_mk running which is monitoring the local site and via multisite (which is just great) reports back to the master.
Hope this helps
Cheers
Alex
On Thu, Sep 16, 2010 at 5:37 PM, Florus Both flb@dtecnet.com wrote:
alex sounds good, but can you give some more details?
cheers
Alex
