[Check_mk (english)] brocade_fcport's "no TX buffer credits"
I'm getting a lot of WARNING/CRITICALs about ratio of "no tx credits" on
ports on Brocade switches. I suspect something is wrong in check_mk:
$ check_mk -n -v -p FC_SWITCH_HOSTNAME
Port 18 CRIT - assuming 2Gbit/s, In: 158.47KB/s, Out: 1.74MB/
s, no TX buffer credits: 90.51%(!!), Phy:inSync(6), Op:online(1),
Adm:online(1) (in=162273.698617;;;0;200000000
out=1822393.279242;;;0;200000000 rxframes=756.367023;;;;
txframes=1320.823425;;;; rxcrcs=0;;;; rxencoutframes=0;;;;
c3discards=0;;;; notxcredits=12604.370683;;;:wink:
And in the web interface (a bit later; so the numbers don't match
completely):
Service state: CRIT
Output of check plugin: CRIT - assuming 2Gbit/s, In: 228.34KB/s, Out:
950.65KB/s, no TX buffer credits: 96.31%CRIT, Phy:inSync(6), Op:online
(1), Adm:online(1)
Service performance data: in=233820.355617;;;0;200000000
out=973468.242159;;;0;200000000 rxframes=518.385831;;;;
txframes=753.48073;;;; rxcrcs=0;;;; rxencoutframes=0;;;; c3discards=0;;;;
notxcredits=19660.374087;;;;
Service check command: check_mk-brocade_fcport
Note from above output from check_mk:
rxframes = 756
txframes = +1321
sum of frames = 2077
notxcredits = 12604
If this is to make sense, the port would almost have an order of
magnitude more instances of no tx credits compared to transmitted/
received frames; that's weird. Such a port would certainly be in a bad
shape, if the numbers are to be believed, I think. But the switch's
administration interface doesn't have anything bad to say about the port.
Things connected to the port seem to work well. And when I manually
snmpwalk the device and look at rx/tx counters and no_tx_credits counts,
I only see ratios below 1%.
I have started looking at the code for brocade_fcport, but I must say I
have trouble seeing how the peculiar numbers are calculated.
At this point, we have 13 FC ports in state CRITICAL and 6 FC ports on a
handful of different Brocade FC switches in state WARNING because of "no
TX buffer credits"; if this were really true, I would expect a lot of
derived operational problems - which doesn't seem to be the case.
Does someone have comments about "no tx credits" and the brocade_fcport
check?
Regards,
Troels Arvin <troels@arvin.dk>
http://troels.arvin.dk/
As follow-up:
At 12:26:
SW-MIB::swFCPortTxFrames.18 = Counter32: 3966693971
SW-MIB::swFCPortRxFrames.18 = Counter32: 2908513707
SW-MIB::swFCPortNoTxCredits.18 = Counter32: 72177326
At 15:50:
SW-MIB::swFCPortTxFrames.18 = Counter32: 4291732356
SW-MIB::swFCPortRxFrames.18 = Counter32: 2917664796
SW-MIB::swFCPortNoTxCredits.18 = Counter32: 74309947
Deltas:
SW-MIB::swFCPortTxFrames.18: 325038385
SW-MIB::swFCPortRxFrames.18: 9151089
SW-MIB::swFCPortNoTxCredits.18: 2132621
And still, I get a very red CRITICAL regarding "no TX buffer credits" for
port 18 almost constantly.
I wonder how to debug this further.
Regards,
Hello again,
On Thursday, January 12, I wrote
Deltas:
Please disregard the above; they reflect an off-by-one error in my
reading of SNMP values (Brocade numbers ports from 0 in most cases, but
when viewing via SNMP, they start from 1.)
It seems check_mk is right about our FC switches really having enormous
amounts of NoTxCredits on some of the ports.
Regards,
Hello again,
> Deltas:
Thanks for updating us, this check is rather hard to validate short of
running
a full SAN including bottlenecks - I'm glad the check was correct after
all.
Regarding your numbers - the NoTxCredits rate is under 1%, which is not
*that* bad, unless you are indeed seeing latency issues?
Is it some kind of long range link or an ISL?
Florian
On Mon, 16 Jan 2012 10:40:08 +0000 (UTC), Troels Arvin <troels@arvin.dk> wrote:
Mathias Kettner GmbH | \/ | |/ / M A T H I A S K E T T N E R
Florian Heigl | |\/| | ' /
Steinstr. 44 | | | | . \ Linux Beratung & Schulung
81667 München |_| |_|_|\_\ http://mathias-kettner.de
Tel.: 089 / 1890 4210
Fax.: 089 / 1890 4211 Mail: fh@mathias-kettner.de
correction: not under - around 1%
On Mon, 16 Jan 2012 11:53:47 +0100, Florian Heigl <fh@mathias-kettner.de> wrote:
Yes, and they were numbers about the wrong port. The problem is described
better here:
- But buttom line is that check_mk seems to be right in pointing out a
problem. (check_mk's brocade code may need better link speed detection,
though; I may return with more on that later).
Regards,
