[Check_mk (english)] bug solaris NFS hanging results in statgrab hanging results in check_mk_agent hangin [suggested fix]
I noticed a bug on Solaris servers. When a NFS mount point is stale it
hangs statgrab which therefore hangs the Check_MK agent and service.
This is obviously quite problematic.
The suggested fix I would like to recommend is change the agent from:
if statgrab > /tmp/statgrab.$$ 2>/dev/null
to:
if statgrab const. cpu. disk. general. load. mem. net. page. proc. swap. user. > /tmp/statgrab.$$ 2>/dev/null
The above basically does a statgrab on all except the file systems (fs.) as that results in a hang.
Could the above suggestion be included in future releases?
PS. I've managed to monitor NFS mount points on solaris by using MRPE with the check_nfs_health.sh nagios plugin.
Thanks,
Divan
Hi Divan,
I've added your change into the official version (GIT). Thanks. Could
you check this out sometime...
Greetings,
Mathias
ยทยทยท
Am 19.08.2010 23:06, schrieb Divan Santana:
if statgrab> /tmp/statgrab.$$ 2>/dev/null
to:
if statgrab const. cpu. disk. general. load. mem. net. page. proc. swap. user.> /tmp/statgrab.$$ 2>/dev/null
Thanks,
Divan
checkmk-en mailing list
