Hello everybody,
I’ve follow the guide in here: https://mathias-kettner.de/checkmk_oracle.html to setup monitoring Oracle with Check_MK
I was successful monitoring Oracle in Linux. But in the AIX 5.3, I can’t run mk_oracle.
It’s error:
ksh: mk_oracle: not found
If I changed:
#!/bin/bash to #!/usr/bin/ksh93, then run:
it’s show an error:
line 638: syntax error at line 688: `(’ unexpected
Anyone see this error before?
Please help.
Thank you.
Cuong.
Hello everybody,
Who’s have the problem like me? Please help.
I’m use check_mk v1.2.8p20
---- On Sun, 16 Apr 2017 20:37:52 +0700 Cuong Le Van lecuong@banbeit.com wrote ----
Hello everybody,
It’s error:
If I changed:
it’s show an error:
Please help.
Thank you.
Cuong.
r.sander
(Robert Sander)
3
You cannot just change the interpreter of a script.
There is a mk_oracle.aix agent plugin which is also a bash script.
Install bash on AIX and try that.
Regards
If I changed:
Robert Sander
Heinlein Support GmbH
Tel: 030 / 405051-43
Fax: 030 / 405051-19
Zwangsangaben lt. §35a GmbHG:
HRB 93818 B / Amtsgericht Berlin-Charlottenburg,
Geschäftsführer: Peer Heinlein -- Sitz: Berlin
Thank Robert Sander very much!
I installed bash on AIX and it’s running now.
Rgds,
Cuong.
---- On Fri, 21 Apr 2017 15:44:26 +0700 Robert Sander r.sander@heinlein-support.de wrote ----
If I changed:
Regards
Robert Sander
http://www.heinlein-support.de
Geschäftsführer: Peer Heinlein – Sitz: Berlin
checkmk-en mailing list
