[Check_mk (english)] Check Host ip adress
Hi list,
I wonder if it is possible to check if a server has the right IP address configured.
Does the inventory which detects the server services and also interfaces keeps a track about the IP values of the interfaces ?
Thks
Guillaume Comte
06 25 85 02 02 | guillaume.comte@blade-group.com
90 avenue des Ternes, 75 017 Paris
Hi Guillaume,
Unfortunately ‘inventory’ doesn’t do that.
IP addresses aren’t stored (well, except the one you enter upon host creation ofcourse).
Easiest way I know of is to use a custom SNMP script to get this information from the devices.
Arno.
On Behalf Of Guillaume Comte
Hi list,
Thks
Guillaume Comte
06
25 85 02 02 |
Just my two cents … I think a local check could do the trick however you would have to either:
- hardcode the IP address you are expecting in the actual check, which kinda sucks
- use some automated tool such as ansible to create / populate the IP address into the local check upon provisioning or some other key point
On 19 Jun 2017, at 12:08, Arno Wijnhoven <arnow@vsnsystemen.nl<mailto:arnow@vsnsystemen.nl>> wrote:
Hi Guillaume,
Arno.
From: checkmk-en [mailto:checkmk-en-bounces@lists.mathias-kettner.de] On Behalf Of Guillaume Comte
Sent: vrijdag 16 juni 2017 12:35
To: checkmk-en@lists.mathias-kettner.de<mailto:checkmk-en@lists.mathias-kettner.de>
Subject: [Check_mk (english)] Check Host ip adress
Hi list,
Thks
Guillaume Comte
06 25 85 02 02 | guillaume.comte@blade-group.com<mailto:guillaume@blade-group.com>
[http://www.code-shadow.com/img/blades.png]
checkmk-en mailing list
I don’t know if this is what you are talking about, but I setup a
cron job
to pull the hostnames and IP addresses using livestatus, then verify
that
the DNS entry for the IP matches the hostname. If any do not match,
it sends me an email. That’s how I catch when the admins re-ip or
re-name
a host without telling us.
On 06/20/2017 10:55 AM, Marius Pana
<arnow@vsnsystemen.nl >
wrote:
                  Hi
Guillaume,
that.
ofcourse).
the devices.
Arno.
[mailto:checkmk-en-bounces@lists.mathias-kettner.de] **On Behalf Of ** Guillaume
Comte
Sent: vrijdag 16
juni 2017 12:35
Subject: [Check_mk
Hi list,
Thks
** Guillaume
Comte**
06 25 85
75 017 Paris
                                               ![](http://www.code-shadow.com/img/blades.png)
checkmk-en@lists.mathias-kettner.dehttp://lists.mathias-kettner.de/mailman/listinfo/checkmk-en
Thanks to point me to the livestatus, i wasn’t aware of this functionnality and it gives me much more idea of what i could achieve using it
I will dig this way
Thanks again
2017-06-20 18:42 GMT+02:00 Jam Mulch spammagnet10@gmail.com:
I don't know if this is what you are talking about, but I setup a
cron job
that
it sends me an email. That's how I catch when the admins re-ip or
re-name
wrote:
                  Hi
Guillaume,
that.
ofcourse).
the devices.
Arno.
Comte
Sent: vrijdag 16
juni 2017 12:35
Subject: [Check_mk
Hi list,
Thks
** Guillaume
Comte**
06 25 85
75 017 Paris
Guillaume Comte
