I'm trying to configure a check_http service with the option -d String to expect in header.
If I use a "fixed" string like Location: https://<url>/test all is working as expected.
So I tried to use it in a ruleset with $_HOSTADDRESS_4$ but this doesn't work but I need
to generalize this rule (because I have hundred of hosts...).
Are regex support in WATO's field "String to expect in response header"?
Update: It seems that $_HOSTADDRESS_4$ is translated to the right value, but I still get
an
HTTP CRITICAL: HTTP/1.1 302 - header 'Location: <...> not found on <...>' - 782 bytes in 0.193 second response time
The first location url is in format https://<url>...%27 <-- that's strange, why "...%27"?
How can I debug this in detail? on the cli it's working fine at all (but I cannot check the $_HOSTADDRESS_4$ substitution
Thx!
Regards
Guenther
Gesendet: Samstag, 16. November 2019 um 10:25 Uhr
Von: guenther.rasch@gmx.at
An: checkmk-en@lists.mathias-kettner.de
Betreff: check_http and -d option / expressions possible?
Am 16.11.2019 um 10:26 schrieb guenther.rasch@gmx.at:
don't understand how a tag can help? I need an option to verify if the Location-string
in the header is set to the right URL. To generalize this option I try to use the
$_HOSTADDRESS_4$. The variable is tranlated but the output / result is still critical.
Do you know how I can get more detailed output because "https://<part-of-the-url>...%27"
is all I can see. <part-of-the-url> is right thats why I thought the variable is
translated.
Regards
Guenther
Gesendet: Samstag, 16. November 2019 um 12:38 Uhr
Von: "Ralf Prengel" <ralf.prengel@rprengel.de>
An: guenther.rasch@gmx.at
Betreff: Re: [Check_mk (english)] check_http and -d option / expressions possible?
using a tag is no solution?
Ralf
Von meinem iPad gesendet
> Hi,
> Thx!
> Regards
> Guenther
> _______________________________________________
> checkmk-en mailing list
> Manage your subscription or unsubscribe
> https://lists.mathias-kettner.de/cgi-bin/mailman/listinfo/checkmk-en
Very strange behaviour. Done the call at the command line with the -d '/main/main.do'
Verified it on the check-mk-service description page:
'-d' '/main/main.do' '-j' 'GET' '-H' '$_HOSTADDRESS_4$' '--sni' '$_HOSTADDRESS_4$'
The options are the same as at the commandline; but the result check is
HTTP CRITICAL: HTTP/1.1 302 - header '/main/main.do' not found on ....
But on the commandline it works fine (as I said, same call).
Any ideas?
Regards
Guenther
Ralf
> Hi,
> Thx!
> Regards
> Guenther
